I'm writing this in the hope that others like me can resolv their problem with the dead EPIA-M mainboard.The symptoms where.. on power-up .. it would make 2 high pich beeps followed by 2 low pich beeps..turned out that is the error code for dead BIOS.OK so u have a dead bios and a mobo that won't boot for various reasons.. from flashing a wrong or corrupted bios or else.Apart from the other ways to go around the problem like buying a new chip already flashed or flash the chip with a dedicated flasher u can follow on this simple guide.You should at least have some experience in DIY in computers .1. Find a mobo of an old pc that uses the same socket for the bios chip.if it uses award bios even better.I used a biostar p4m800-m7a mobo to do this.No need for it to have a hdd or something special attached to it.. power source and cd or dvd/rom will do.2. Try to see if it boots, if all ok..3. Get you hands on the Hiren's boot cd..burn it and boot from cd..it has in the Dos program list... in the next page BIOS/CMOS UTILITIES. Select uniflash 1.4.. i did it with the 1.4 on the hiren's boot cd 10.1 maybe if they update it it will work also.It will tell you the name of the bios chip and some details..make a backup of original chip just in case.4.On other pc download the 109.BIN file .. the bios file known to be stable for the EPIA-M board. You can find it on some forum.. i can't remember now..I thank them by the way.Same the file on a fat32 usb key.5.On the surogate board with uniflash started.. comes the tricky part: u have to get hold of some good tools and pull the bios chip out while it's running... don't worry, nothing will happen.6. Pull out the dead bios chip of EPIA-M and put it in the surogate board.These steps must be done with absolute care.If you think you can't do it, wait or call a friend with more experience or get hold of the right tools7. Now with the dead bios chip in place.. select in uniflash, rediscover bios chip.. or something like that,..can't remember well.. but you get it when you see the screen... the sst bios of the EPIA-M NOW SHOWS UP...8. select flash bios and select the file on the root of the usb key by typing C:\109.bin.. if no hdd attached.. the key is seen as C, otherwise use letter accordingly.It flashes the bios in less that 10 seconds.. and says ok.. power off surogate mobo.. replace bios chip with original.. and enjoy now your EPIA-M mainboard again.If you'd like to thank me or ask details..mail me at [email protected]
if your computer came with a motherboard disc the sound drivers could be on itclick start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingstherealsoclick start control panel sounds and audio devices select advanced there might be a tick in the mute box untick itif his does not fix the problemclick start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume iconsystem select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might checkthe speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is goodtry cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps youif you dont have a motherboard disc you will have to download the drivers
The wired mouse is more responsive for that exact reason, it's connected by a wire. The cheaper bluetooth wireless setups can have poorer quality parts in them so it won't connect as well as a brand name wireless mouse. Try plugging the receiver into a different USB port. Some ports are set up for faster connection. It might be marked with an "SS" or the spacer in the port hole will be coloured blue. You could also check and update the software 'drivers' to see if that helps.
Phone your Internet Provider that you require their newest Home Hub and engineer to install it and check the cable / phone connections to your home. Tell them the service is terrible and if they don't fix it, you are changing companies. In the last 20 years, I have had 4 upgrades of routers.It is not you or your devices, it is the equipment from your ISP or the cables that supply that service...
The issue with the Vaddio ProductionVIEW 999-5700-000 where both Control A and Control B lights are on during boot, resulting in a loss of camera control, may be sporadic and hard to recreate intentionally. It could indicate intermittent hardware or firmware issues. To address this:Ensure all connections and cables are secure.Check for any firmware updates or patches provided by Vaddio to address potential bugs.If the problem persists, consider contacting Vaddio's customer support for specific diagnostics and potential solutions, as this issue might require specialized technical expertise.
Freeviewhttps://www.freeview.co.uk > tv-guide
The biggest shows live and on demand all for free with Freeview Play. find out more · BBC ONE Lon. Series 23: 40. Devon and Dorset. Escape to the Country · BBC ...
TVGuidehttps://www.tvguide.co.uk > mobile
TV Guide for all UK channels including Sky, Freeview, Virgin and Netflix. See what's on TV now and next and search for your favourite shows.
Please use Geeksquad to help transfer your data from that hard drive before throwing it away. If it's malfunctioning now, you're not going to want to store anymore data on it.
Thank you.
Cloud computing is the delivery of computing services via the internet rather than through local servers or personal devices. Servers, storage, databases, networking, software, analytics, and intelligence are all examples of computing services. These services are transferred outside of an organization's firewall and are available over the internet. Cloud computing reduces operating expenses and enables efficient scaling because consumers pay on an as-needed or pay-per-use basis.
As Cloud Computing is a buzzword in the IT industry, If you want to pursue a career in Cloud Computing then you can go for a Cloud Computing Course.
CHARACTERISTICS OF CLOUD COMPUTING
According to the National Institute of Standards and Technology (NIST), all true cloud environments have five key characteristics:
On-demand self-service: Cloud customers can easily sign up for, pay for, and begin using cloud resources without the assistance of a sales professional.
Customers can access cloud services through a wide network, such as the internet.
Resource pooling occurs when multiple types of consumers (individuals, organisations, or departments within an organisation) use the same servers, storage, or other computing resources.
Rapid flexibility or expansion: Cloud users can simply scale up or down their utilisation of resources as their needs change.
Measured service: Instead of purchasing hardware or software up ahead, customers pay for the amount of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how much resources different departments within an organisation use.)
Resource pooling occurs when multiple types of consumers (individuals, organizations, or departments within an organization) use the same servers, storage, or other computing resources.
Rapid flexibility or expansion: Cloud users can simply scale up or down their utilization of resources as their needs change.
Measured service: Instead of purchasing hardware or software up ahead, customers pay for the number of resources they use in a certain period of time. (It should be noted that in a private cloud, this metered service usually entails some type of chargebacks in which IT keeps track of how many resources different departments within an organization use.)
Contact Support. 'Protection Off', means that it is turned off and not protecting you. Do you also have Windows Defender active on the machine? Windows may have turned the competitor off, or your subscription has expired.
https://www.glarysoft.com > malware-hunter > download
Malware Hunter is an award-winning product that provides comprehensive protection against all types of threats, secures your data, protects your privacy and ...
Operating System: Designed for Windows XP/...
Release Date: Sep. 07, 2021
File Size: 80.67 MB
If it as a dual bios chip, restore from the older bios to overcome issues.
The only place the bios updates are available is from the manufacturers web site, if available.
