Info at http://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20PRESS%201052&code=C-2101 may be helpful.
you may need to make service call.
SOURCE: ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
