It seems you have done all the troubleshooting yourself. You can't do a full factory reset, because you can't see the screen. You either have an internal power supply unit failure or a control board failure. Neither are really home repairs. A new one is $147, or you can take it to an HP Service Centre. I am sure not to answer you wanted but it has failed.
Here is a Troubleshooting Manual. HP always do things in style! Low-voltage power supply on Page 34.
Description:The product has experienced a problem with one of the motors.
Remedy:Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
SOURCE:HP color laser jet printer is displaying error Developing disengaging motor error. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step.
I Hope It Works.
did you read the HP page, on your M401 page.
and read the trouble shooting guide there,
all error codes are there, to read 24./7.
or ask here and they will point to the page. for you. https://h30434.www3.hp.com/
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
