20 Most Recent HP 5590 ScanJet Flatbed Scanner Questions & Answers
scan at a lower resolution .
Maybe increase virtual memory of p.c. in Windows o/s
HP 5590 ScanJet... | Answered on Aug 12, 2015
You can get a service manual at this website address (HP website):
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Scanjet+Scanner&qry=instruction+manual&submit.x=7&submit.y=4&ctry=emea_africa&lc=en&dlc=en&mode=fb&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
HP 5590 ScanJet... | Answered on Mar 07, 2015
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
HP 5590 ScanJet... | Answered on Jul 05, 2011
This model scanner doesn't have any built-in way to connect to a network. You need to connect it to one of the wired ports on your router with a USB print server like this. The server provides the link between the scanner and your network so that it can be used by any connected computer.
HP 5590 ScanJet... | Answered on Dec 06, 2010
I need the scanned documents be saved as pdf in HP scanjet 5590
HP 5590 ScanJet... | Answered on Sep 14, 2010
this is a generic problem as many customer faced a problem when using this scanjet scanner with windows vista to be particular windows vista as well as win 7.
solution:please fiollow this link..you will find the answer to your queries as well as many other information which is required..
have a nice day!!!
HP 5590 ScanJet... | Answered on Jun 22, 2010
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
HP 5590 ScanJet... | Answered on Jun 18, 2010
You can download ScanJet driver from here.
HP 5590 ScanJet... | Answered on May 13, 2010
How to share scanjet 5590 with other's pc.
HP 5590 ScanJet... | Answered on Jan 09, 2010
you can find all the softwares and drivers needed for your model here. Then select your operating system and proceed to download.
I hope this is usefull to you
HP 5590 ScanJet... | Answered on Jan 05, 2010
You could be feeding the paper upside down.
Try turning the sheets over and re-scan.
The paper travels into the scanner from the top and then onto the glass. This means the paper should start out with printing face up.
HP 5590 ScanJet... | Answered on Dec 22, 2009
I would do a manual uninstall and make sure to do the device utility at the end and follow the directions step by step from this link.
Redownload the drivers and make sure they are for 10.3.9 and the full feature software to make sure the right drivers are going to be installed.
Also I would unplug the unit while it is on and plug in directly to the wall to make sure not a power issue. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all or it gives error messages.
HP 5590 ScanJet... | Answered on Nov 25, 2009
In the scan options there should be a box to check for multipe scans or pages.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
HP 5590 ScanJet... | Answered on Nov 09, 2009
You can go into the back of the printer and open it up. HP has great instructions on their site.
HP 5590 ScanJet... | Answered on Oct 09, 2009
Go into your "printer properties" and make sure that someone hasn't inadvertantly changed the page settings.
HP 5590 ScanJet... | Answered on Oct 05, 2009
HP 5590 ScanJet Flatbed Scanner Logo
45 questions posted
Clive
Clive
View Most Popular
ScanJet HP
  • ScanJet HP
Most Popular Question
about hp scanjet 5590 flatbed scanner
  • Office Equipment & Supplies
