20 Most Recent HP LaserJet Pro 400 M401DN Laser Printer Questions & Answers
What is 59.A0 Error in hp laserjet pro 400 printer?
This is usually a motor code, turn off, unplug wait 2 to 3 minutes plug in and try, may work good luck
10/17/2021 1:55:58 PM • HP LaserJet Pro... • Answered on Oct 17, 2021
How do I fix the error code 52 on my HP printer?
The correct solution is to replace the scanner with the correct M401 model not one from an older HP. The scan speeds could be different, the motors could be different which would make the formatter think that the motor was turning too slow.
7/29/2021 7:21:36 AM • HP LaserJet Pro... • Answered on Jul 29, 2021
Hp laserjet pro 400 m401dn keeps going offline.
I would upgrade the driver first. You can also do a factory refresh which brings the printer back to the original condition. Make sure that you get the ip address off the config page just in case you need to reset the settings.
7/26/2021 8:28:47 AM • HP LaserJet Pro... • Answered on Jul 26, 2021
How can solve 59.3 error hp laser jet pro 402
hp laser jet pro 402 printer 50.2 or 59.3 error has first check your power WATS then fussier & heat element
7/25/2021 10:26:08 AM • HP LaserJet Pro... • Answered on Jul 25, 2021
2answers
HP Laser Pro 400 m401n 50.2 fuser error
dscn9978-ozzfb0gelsgzs3bqd14neetn-3-0.jpg How to resolve this error???????
10/4/2018 3:48:25 PM • HP LaserJet Pro... • Answered on Oct 04, 2018
2answers
Hp laserjet pro 400 paper jam in cartridge area
One of my customers has roughly 100 of these pro 400 in service. Many of the constantly display "Jam in cartridge area" We have found the message is not related to any part of the cartridge area. The exit flag spring in the back of the fuser seems to be lightly wound. Carefully turn the end of the spring that rests on the plastic ( closest to you when looking at it) one full turn over the top of the pivot and re-secure back on the piece of plastic. For safe measure, bend the tip of the spring down the piece of plastic so it won't unwind. Secure the tip with a small amount of glue. We dis this to all of the machines in question and have not had a single problem since
/uploads/images/8_13_2014_3_21_55_pm.jpg
/uploads/images/8_15_2014_7_14_32_pm.jpg
10/3/2018 7:06:08 PM • HP LaserJet Pro... • Answered on Oct 03, 2018
2answers
Says I have a paper jam and there is none
Try Opening and closing all doors and parts again.
3/14/2018 3:07:41 PM • HP LaserJet Pro... • Answered on Mar 14, 2018
My printer hp laser pro 400 show message 50.3
hello ,,
50.x Fuser Error
Description The product has experienced an error with the fuser. Recommended action Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. Turn off the product, wait at least 25 minutes, and then turn on the product. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on. If the message persists, contact HP support.
12/19/2017 12:55:48 PM • HP LaserJet Pro... • Answered on Dec 19, 2017
HP laserjet pro m401 dne does not print
you replace toner cartridge 80 a then ask questions
2/25/2017 6:51:11 AM • HP LaserJet Pro... • Answered on Feb 25, 2017
HP LaserJet Pro 400 M401DN Laser Printer keeps jamming at cartridge.
Is the paper stopping just at the cartridge or is it in the fuser. We have had a few of these fail with bad fusers. The only time we have had a cartridge issue is if the drive shaft on the right side of the cartridge falls off.
9/14/2016 10:40:45 PM • HP LaserJet Pro... • Answered on Sep 14, 2016
Driver is invalid Press [OK] to contnue
Uninstall the driver and reinstall using drivers downloaded from HP.
3/30/2016 2:32:07 AM • HP LaserJet Pro... • Answered on Mar 30, 2016
0answers
2answers
Printer printing crazy symbols
just delete all print from printer and restart printer and computer then try again happen because some cancellation of print during priting
12/5/2015 12:16:43 PM • HP LaserJet Pro... • Answered on Dec 05, 2015
How to stop paper jams
Chk media specification. Chk paper pick rollers Clean paper path sensors & flags if they are dusty. Avoid refill cartridges. .
9/9/2015 1:30:11 PM • HP LaserJet Pro... • Answered on Sep 09, 2015
HP LaserJet Pro 400 M401DN Laser Printer Logo
196 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
fix error code 52
  • Office Equipment & Supplies
