20 Most Recent HP DesignJet 330 InkJet Printer Questions & Answers
Firmware failure with inbuilt ROM
unfortunatly the only fix is to replace the firmware chip itself which requires a new main PCA/formatter, I would suggest with the age of this unit that would be most difficult to get hold of and would probably cost more to repair than it would be to procure a 2nd hand more recent unit
1/31/2014 12:08:38 PM • HP DesignJet 330... • Answered on Jan 31, 2014
Designjet 330 all lights on the front panel are
A clog print head noozle sometimes the cause of this problem, so try to clean it and try plug again
1/12/2011 3:09:07 AM • HP DesignJet 330... • Answered on Jan 12, 2011
Keep getting film + error flashing lights which
Probably a bad trailing cable. I've seen it many times.
4/26/2010 9:12:07 PM • HP DesignJet 330... • Answered on Apr 26, 2010
My HP DesignJet 330 prints for the first 6
Guys
1. Thanks for coming up for air
2. We figured out the problem
3. It's a master panel board in the bottom right corner of the printer
4. At this time we will be throwing out this HP 330 and getting another
Thanks for your help.
10/4/2009 7:53:00 AM • HP DesignJet 330... • Answered on Oct 04, 2009
2answers
Film + error lights flash. I have replaced the ink
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
9/24/2009 11:40:29 AM • HP DesignJet 330... • Answered on Sep 24, 2009
When turned on goes through routine with lights but no mechanical
Sounds like a partial power supply failure; the output for the motor drive(s) has failed. This may be a separate assembly but some covers may need to be removed to determine this.
3/17/2009 7:39:35 PM • HP DesignJet 330... • Answered on Mar 17, 2009
Can't find a 32 MB Memory module in South Africa. Where & how can I order one ??
The same Ram can be found in old desktop computers, 486 is about the right time for a 16mb or 32mb RAM chip.
1/14/2009 1:06:00 AM • HP DesignJet 330... • Answered on Jan 14, 2009
Loading Media for DesignJet 330
played with the set up procedure and it fixed itself. thx for the followup
9/9/2008 11:49:23 AM • HP DesignJet 330... • Answered on Sep 09, 2008
Service
see the driver are properly installed or if you can do litte bit of serviceing like add oil on the rod . bye
9/28/2007 5:46:00 AM • HP DesignJet 330... • Answered on Sep 28, 2007
Hi Hp designjet t520 printer when i print the reportthe cyan color change his place with magenta color and yellow is dark thanks i need to help
check the catridges thier must be a mixing up of color when you were refilling the catridges
3/15/2022 4:11:23 PM • HP DesignJet... • Answered on Mar 15, 2022
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
5/8/2020 3:49:18 PM • HP DesignJet... • Answered on May 08, 2020
HP Designjet T3500 Ethernet port not working
To solve issues visit https://support.hp.com/in-en/document/c04530811 to get quick support call our Toll-Free 1 888 224 4280
7/30/2018 5:24:16 AM • HP DesignJet... • Answered on Jul 30, 2018
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead. My advice is not to stock up on cartridges because of this problem. If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
4/15/2015 5:28:53 PM • HP DesignJet... • Answered on Apr 15, 2015
HP DesignJet 330 InkJet Printer Logo
Popular Tags
12 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
film error lights flash replaced ink
  • Office Equipment & Supplies
