Washing Machines Logo
Beverly Smith Murphy Posted on Feb 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire Washer Model FAHE4044MWO We need to find out what is making the the loud whirring in spin cycles? My husband says it sound like a bearing going bad. But I cannot find a part for a bearing.
rd2xpld
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 107 Answers
  • Posted on Feb 25, 2019
rd2xpld
Expert
Level 2:
New Friend:
Teacher:
Answers
107
Questions
Helped
29190
Points
314
Pretty sure you will need the motor since that is where the bearing is located. Get the part # off the motor and search by that.
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 20, 2007
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Anonymous
  • 1028 Answers
  • Posted on Jul 20, 2008
SOURCE: Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Anonymous
  • 5 Answers
  • Posted on Aug 02, 2009
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Anonymous
  • Posted on Oct 20, 2009
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Anonymous
  • 1304 Answers
  • Posted on Oct 27, 2009
SOURCE: My neptune washer is making a loud noise when in
unfortunately yes,
your main seal on the oter tub is drying out, and will continue to get louder until either the motor control fries due to resistance or it just seizes up
it can be reapired but you will need an new outer tub 500.00 spinner assembly 200.00 i could talk you through the reapir,, it really it that easy, but
for 700.00 you could easily replace the machine for brand new
i tell you this at the risk of a bad rating beacuse i bear bad new,, but i wanted to be as honest as possible to allow you an informed decision before you proceeded
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Frigidaire fahe4044mwo shakes in spin cycle
Good Afternoon Rob,
I understand your Frigidaire washer, model# FAHE4044mw0, shakes in the spin cycle, even after making sure your appliance is leveled. I also see that this occurs with small loads. Please make sure that your load is evenly distributed. If not, stop your washer and redistribute the load. Also make sure that the load is not too small. Try adding 1 or 2 similar items to even out the load. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Good Morning Friend,
I understand that your Frigidaire washer, model# FAHE4044MW0, is shaking in the spin cycle. First, please check and make sure that your washer is resting firmly on the ground and does not move if you try to shake it. Secondly, make sure that all shipping bolts have been removed when you installed your appliance. Thirdly, make sure the load is not too small. Add a couple of similar items to even out the load. Lastly, make sure that the wash load is distributed evenly. Stop your washer and rearrange the load if you need to. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire front load washer model GLTF1240ASO makes a loud noise durring spin cycle
Most likely the drum bearings are gone, especially if you have some play. You need a bearing and seal kit which is fairly inexpensive but it is a pretty big job. The entire inner drum must come out so it requires the disassembly of quite a bit of the machine.
5helpful
2answers
My washer makes a loud noise in the spin cycle. It's a Frigidaire Gallery Washer Model 417.39012890. Any idea how expensive the repair will be?
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
6helpful
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
4helpful
2answers
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
