SOURCE: Kitchenaid superba refrigerator
it twists off and go here and download a free manual http://www.kitchenaid.com/custserv/service.jsp
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
SOURCE: HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
SOURCE: change filter light
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Sea Breeze
SOURCE: I have a Hotpoint Refrigerator Model HSS25GFPH and
My daughter's Hotpoint has the same problem (not sure of the exact model). Discovered that the water line inside the freezer door is freezing up. However, I don't know why and the dealer says they have no clue either. This may be your problem.
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
