20 Most Recent
Hotpoint HMT40 Stainless Steel Bottom Freezer Refrigerator Questions & Answers
Cant change temperature in fridge
you have to send the full model number off of the fridge,open the fridge door,look up near the ceiling on the left or right hand wall depending on your model and you'll see a tag with the model and serial numbers,just send the model number,g.e. makes hotpoint machines so most likely you have a bad computer board or mother board same thing,,usually it takes a wr55x10942 and it's around 150 to 200 hundred dollars but need the model number to check it,some take a different board but this is the common board.you'll find the board located on the back outside wall of the fridge,pull it out away from the wall,remove the screws and cover but first unplug the machine before you touch the board or remove the cover,there are 4 plastic clips holding the board in place,i use a needlenose plyers to pinch the clips and slide the bord out one at a time and then you can look at the back of the board to see if it has any burn marks on it,everything runs through the board and g.e. has had problems with the boards.don't order this board until you make sure this is the part for your machine by checking it with the model number .good luck.
Problem with drawer configuration. I have a Hotpoint Freezer. Model FZA84.
Does the problem move with the drawer when you shuffled them or did it do the same thing in the same position? If it moved it's the drawer causing the issue, if it stayed in the same place it's the freezer itself.
Empty the offending drawer and have a good look at it. A lot of front panels on freezer drawers are a 'push on' fit so check the front is clipped on correctly on both sides. Next check the runner rails and back panel of the area that drawer goes into. It might be something as simple as a lump of ice or something stuck to the side/back or a something in the drawer above or below blocking it.
6/28/2023 5:17:16 PM •
Hotpoint...
Answered
on Jun 28, 2023
I heard some clicking noises
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
5/17/2023 6:40:48 AM •
Hotpoint...
Answered
on May 17, 2023
Can you disconnect the ice maker only on a hotpoint ctx21ga refrigerater
Yes, you can disconnect the ice maker on a Hotpoint CTX21GA refrigerator. Here are the general steps to follow:
- Unplug the refrigerator from the electrical outlet or turn off the power at the circuit breaker.
- Locate the water supply line that runs from the back of the refrigerator to the ice maker. It is typically a flexible plastic or copper tube.
- Find the valve where the water supply line connects to the refrigerator. It may be located behind a panel or cover.
- Turn off the water supply to the refrigerator by closing the valve. You may need to turn it clockwise to shut it off.
- Disconnect the water supply line from the valve by loosening the compression nut or other connector.
- Locate the ice maker inside the freezer compartment. It is usually mounted on the back wall or ceiling.
- Unplug the ice maker's electrical connector by pulling it out of the socket.
- Remove any screws or mounting brackets that hold the ice maker in place and gently pull it out of the freezer compartment.
- If you wish to permanently remove the ice maker, you can disconnect the wiring harness and remove the mounting bracket.
- If you plan to reconnect the ice maker in the future, you can leave the wiring harness connected and store the ice maker in a safe place.
- Reconnect the water supply line to the valve and turn the water supply back on.
- Plug the refrigerator back in or turn the power back on at the circuit breaker.
2/21/2023 12:04:57 PM •
Hotpoint...
Answered
on Feb 21, 2023
How to change the fast freeze flap on a hotpoint HUZ 1221
- Remove any food or items from the freezer compartment.
- Locate the fast freeze flap at the back of the freezer compartment. This is usually a small plastic or metal door that can be opened and closed.
- Use a Phillips head screwdriver to remove the screws or clips that secure the fast freeze flap in place.
- Carefully lift the fast freeze flap off of its hinges and set it aside.
- Take the new fast freeze flap and place it in the same position as the old one, making sure the hinges are aligned properly.
- Secure the new fast freeze flap in place using the screws or clips that you removed earlier.
- Close the freezer compartment door and return any food or items to the freezer.
1/3/2023 11:30:25 PM •
Hotpoint...
Answered
on Jan 03, 2023
