Maytag Refrigerators • Uploaded on Aug 26, 2013
Sounds to me your model MSD2651HEB has two problems. If you see icicle forming near where the water enters the ice maker the problem is the water control valve is defective and allowing water to enter the ice maker even after the ice maker is already filled with the next ice harvest. To repair the ice maker overfill problem you will need to replace the=> 67006531 Dual Water Control Valve 67006531 Dual Water Contriol Valve. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks, Sea Breeze
• Owner's Manuals (1)
• MSD2651HEB.pdf (4536.63 KB)
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. Get Adobe Acrobat ReaderFor other models Click HERE
131 questions posted
822 Questions
518 Questions
315 Questions
239 Questions
