20 Most Recent Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Questions & Answers
Keep getting ice buildup on my ice dispenser
Is the ice chute door closing tightly
1/1/2018 11:57:16 AM • Hotpoint... • Answered on Jan 01, 2018
2answers
I have a hotpoint HSS251FMDWW, for the last year,
It sounds like your auto defroster is not work
11/29/2017 9:27:34 PM • Hotpoint... • Answered on Nov 29, 2017
Hotpoint Refridgerator HSS251FMBWW, Ice dispenser runs by itself
Hi! Hopefully the manual of a similar Hotpoint fridge witll help you. There may be not a unique reason of this problem. Seems that it might be a problem of a cube dispenser. https://manualsbrain.com/en/manuals/820483/?page=32
8/9/2017 11:27:29 AM • Hotpoint... • Answered on Aug 09, 2017
Very hot to touch between fridge and freezer on
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
4/10/2016 8:41:17 AM • Hotpoint... • Answered on Apr 10, 2016
Icemaker not making ice
Check the arm that is on the maker and make sure it's down
4/28/2015 2:48:02 PM • Hotpoint... • Answered on Apr 28, 2015
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
3/13/2015 12:40:48 AM • Hotpoint... • Answered on Mar 13, 2015
2answers
When the refridgerator kicks to run it now has a
your fan on frig. is going bad.
1/23/2015 7:51:03 PM • Hotpoint... • Answered on Jan 23, 2015
2answers
Where is the hotpoint HSS251FMD WW defrost timer
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
10/16/2014 12:58:59 AM • Hotpoint... • Answered on Oct 16, 2014
Leaking and fan stops then starts?
Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
6/12/2014 12:28:29 PM • Hotpoint... • Answered on Jun 12, 2014
2answers
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
5/26/2014 11:04:09 PM • Hotpoint... • Answered on May 26, 2014
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
4/13/2014 9:12:33 PM • Hotpoint... • Answered on Apr 13, 2014
Hotpoint refrigerator side by side
All of the cold air for the refrigerator comes from the freezer. Is there any ice build up behind the shelves in your freezer?
3/2/2014 3:08:16 PM • Hotpoint... • Answered on Mar 02, 2014
0answers
Frdge and freezer warm compressor wont start no power to start capacitor
Hi, Pull unit away from the wall, unplug it. There is a panel above the compressor area< remove the panel and release the clips to the board, inspect the board for burns, you will find that the large black relay has a broken weld to the board. Only good repair for this is to replace the board, P# WR55X10942. Read instruction carefully as some unit require a slight modification to a sensor harness and others don't. This issue was common in the 06-08 models as the weld would weaken and burn. Good luck if you need more assistance, just ask. I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/16/2013 1:10:10 PM • Hotpoint... • Answered on Dec 16, 2013
0answers
Hss251fmd
Be the first to answer 6/25/2013 4:03:11 AM • Hotpoint... • Posted on Jun 25, 2013Be the first to answer
2answers
Refrig not cooling, freezer is not cooling.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3/27/2013 1:40:28 AM • Hotpoint... • Answered on Mar 27, 2013
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
211 questions posted
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
hotpoint refrigerator leaking water from
  • Refrigerators
