Exercise & Fitness Logo
Posted on Feb 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A NORDIC TRACK 2450 COMMERCIAL TREDMILL WITH AN EXTENDED WARRANTY CONTRACT. After I downloaded your latest If it software I haven't been able to have the machine connect to the internet.
ADMIN Andrew
Level 3:
Top Expert:
  • Nordic Track Master 66,975 Answers
  • Posted on Feb 08, 2022
ADMIN Andrew
Nordic Track Master
Level 3:
Top Expert:
Answers
66975
Questions
Helped
5089081
Points
379905
" After I downloaded **your** latest software ".
We are FIXYA dot com. We are not who you think we are and we are certainly not Nordic. Contact them direct via Phone.
ray gallant
Level 3:
Top Expert:
  • Nordic Track Master 74,163 Answers
  • Posted on Feb 06, 2022
ray gallant
Nordic Track Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657759
Points
561709
USE THE WARRANTY
  • ADMIN Andrew
    ADMIN Andrew Jul 14, 2022
    Where are you Ray? I haven't seen you for the longest time!
5 Related Answers
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Mar 18, 2010
SOURCE: how to remove hood no screws
The motor shroud has 3 Phillips screws under the front under belly that releases shroud you should be able feel them with finger tips.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Jun 14, 2010
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Anonymous
  • 218 Answers
  • Posted on Aug 11, 2010
SOURCE: Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Anonymous
  • Posted on Jan 11, 2011
SOURCE: I need an owners manual
Try this link http://service.nordictrack.com/CustomerService/manualsProductList.do?manufacturer=NT&model=nt275000&modelName=&language=&x=31&y=12
Pukaman
  • 29 Answers
  • Posted on Apr 12, 2012
SOURCE: 9 month old Nordic Track
I just went to a physical therapist who has two NordicTrack treadmills that are down with the exact same problem. The plastic pulley that is on the belt spindle is spun. How you check this is remove the front cover. (four screws in the front, two under the sides) Now, with the cover off start up the treadmill at two miles per hour and walk on the thing, then try to slow the machine down. If this pulley has failed you will see it spin on the belt roller.
I have not yet contacted the company about this design defect, but did read that some people have drilled through the pulley on opposite sides and installed a small screw into the roller (being careful not to drill into the bearings)
I am saddened by this defect. This machine has a lot of innovative designs that are fantastic and great quality in all other respects.
How do you turn off demo mode on a nordic track 2450 NTL 17219
https://www.manualslib.com/manual/583110/Nordictrack-Commerical-2450-Treadmill.html?page=27
Quoting from manual above (may be similar model if not the same.)
7. Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the treadmill is displayed
in a store. While the demo mode is turned on, the
console will function normally when you plug in
the power cord, press the power switch into the
reset position, and insert the key into the console.
However, when you remove the key, the screen will
show a demo presentation.
To turn on or turn off the display demo mode, first
touch the Demo Mode button. Next, touch the On
checkbox or the Off checkbox.
I have nordic track 990. Was walking on tredmil felt like it was hestitating now the belt wont move
the belt has two rollers the front one has a motor roller adjustment screw like the one on a car alternator; tighten this screw untill the rolller grips the belt.
Looking for a replacement safety key for my reebok tredmill
Best place to check is ebay.
http://www.ebay.com/sch/i.html?_nkw=Nordic+Track+Reebok+Treadmill+Safety+Key
How do u restart a welso 5.9 tredmill
See about getting an operator manual:
www.weslo.com
Nordic Track commercial 2150 on the i fit screen starts up but then runs in loops, it will not boot up or
Time to replace the Console board CPU, the Clock+power supply inside had been failed.
Treadmill Doctor
Blessing.
[email protected]
cell+whatsAPP:+50588611441
How do I get the motor hood off a nordic track commercial 1500
Download a manual for this model . This will make it easier to find the hidden screws.
2answers
Nordic track commercial 1300 manual
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
