SOURCE: noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
