SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
SOURCE: Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
SOURCE: The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
SOURCE: Need Manual for Frigidaire Gallery Heavy Duty Washer/Dryer Combo Model #FLSG72GCS0
my washer make a loud sound when spinning
