20 Most Recent Frigidaire GLEH1642FS Front Load Electric Laundry Center. 3.1 cu. ft Washer and 5.7 cu. ft. Dryer Capacity, 16 wash cycles, Stainless Steel Dryer Drum, Energy Star, Stainless Steel Wash Basket, Tumble Care Cleaning System, Sound Silencer Plus, precision Dry Moi Questions & Answers
...E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring.
Frigidaire FEQ1442ES Electric Dryer E5b error code - Questions ...
www.fixya.com/search/p439987-frigidaire_feq1442es_electric_dryer/e5b_error_code
Videos
https://www.google.com/search?q=error+code+E5b+on+Frigidaire+affinity+dryer
Frigidaire... | Answered on Mar 21, 2019
If you use fabric softener sheets in your dryer, they eventually will deposit enough residue in your lint trap to close up the mesh. Usually you cannot see the residue, although it is blocking the movement of air through it. My advise would be to remove the lint trap and run it under hot water and clean it well, then try the dryer with the clean lint trap. I hope this works for you and solves your problem.
Frigidaire... | Answered on Jan 02, 2019
Check the owners manual or manufacturers website for error codes. Most likely cause...a bad control board.You tube will most likely have "how to replace" videos for your assistance.
Good luck...
Frigidaire... | Answered on Dec 23, 2018
Typically there is a wiring diagram inside console area or on back of dryer.
Frigidaire... | Answered on Dec 21, 2018
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
Frigidaire... | Answered on Dec 20, 2018
Searspartsdirect.com
Frigidaire... | Answered on Dec 19, 2018
Frigidaire GLEH1642FS Front Load Electric Laundry Center. 3.1 cu. ft Washer and 5.7 cu. ft. Dryer Capacity, 16 wash cycles, Stainless Steel Dryer Drum, Energy Star, Stainless Steel Wash Basket, Tumble Care Cleaning System, Sound Silencer Plus, precision Dry Moi Logo
Popular Tags
1 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
double stack frigidaire washer very
  • Dryers
