I have done the reset procedure by tripping the breaker, and everything seems fine until the cool down.
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
SOURCE: Kenmore range gives
Hi. Unfortunately, this code is indicating that your control board is severely damaged. This will require you to have this damaged control board replaced, asap.
