20 Most Recent
KitchenAid KGSS907SSS Gas Kitchen Range Questions & Answers
Oven door won't close
You should not have been able t force the oven open when in self cleaning mode since u did I am sure that you have damaged the locking mechanism and the solenoid lock inside the top of the oven that sets the lock when doing self cleaning.
this is not a huge problem but it needs to be fixed most likely not by u call an appliance rpair shop in your area and it should cost no more than $150 to fix
Kitchenaid kgss907sss neither the broiler nor the oven will heat with fire. the elecricburner does work however but does not heat well enough. i can hear the igniter click once after turning it on but
For broil burner ignition an oven broiler burner spark electrode is used to ignite the gas. The electrode is a device that sits right next to the broil burner. It functions like a spark plug. As power is applied to it a spark jumps from the spark electrode tip to the to the electrode shield, igniting the gas. If the electrode is broken or worn out the spark may not occur or be intermittent. Visually inspect the electrode assembly for cracks in the porcelain housing or damage to the electrode tip itself. Be aware that a proper ground and the correct polarity of the incoming voltage to the range is necessary for the electrode control to sense the presence of a flame once the burner is ignited.
there is also a spark control module but I don't think that's it usually no spark when bad.
if you need or want parts ck here for your unit.
hope this helps a little
https://www.repairclinic.com/Shop-For-Parts/-x6b677373393037737373/Kgss907sss-Parts
Flames are orange and yellow not blue
A Yellow or Orange indicates your burning too much gas and not enough air. You need to make sure the gas orfaces and air input is clean of grease and gunk, and then adjust the iar input opening to the proper color (Blue) flame.If I can be of any more help, please email me at
[email protected].
"Original Radio Man"
Ed
