20 Most Recent KitchenAid KGSA906PSS Gas Kitchen Range Questions & Answers
2answers
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
11/24/2021 11:50:51 AM • KitchenAid... • Answered on Nov 24, 2021
2answers
E3F3 on kitchen aId Model KGSS907SSS00 while self cleaning
doorlock will not disingage after self clean cycle is through
11/10/2021 10:52:14 AM • KitchenAid... • Answered on Nov 10, 2021
0answers
0answers
Wd sensor open
Be the first to answer 4/3/2017 10:03:02 PM • KitchenAid... • Posted on Apr 03, 2017Be the first to answer
Why won't the burner in my Kitchenaid gas oven stay lit?
Fro memory these have the igniter pack at the rear of the oven once you get the cooker out it's pretty easy to remove & replace it. If you are unsure ring the manufacturers service division they are usually happy to help.
5/8/2014 12:43:52 AM • KitchenAid... • Answered on May 08, 2014
0answers
0answers
Tappan series 110 the igniter is glowing but it wont lite the oven
Is the gas turned on at the stop valve behind the range? Assuming the gas is on, the igniter can glow but not actually be working properly such that the control valve does not open or the valve may be failed. There are electrical measurements for the valve and igniter and related circuit that can be made if you have a clamp on amp meter and a volt meter.
11/20/2013 12:15:55 AM • KitchenAid... • Answered on Nov 20, 2013
0answers
NEED SERVICE MANUAL FOR KITCHENAID MOD
Need the manual for the KitchenAid KGSA906PSS Gas Kitchen Range so I can order parts to have my stove work properly.
11/5/2013 12:22:12 PM • KitchenAid... • Answered on Nov 05, 2013
Close door light remains on oven won't turn on
Check the oven door switch and related wiring. It might be the oven controller.
10/31/2013 3:00:01 PM • KitchenAid... • Answered on Oct 31, 2013
I have a kitchenaid ykess907ss00 i start the self kleen but i open de door at the same time now the light inside stay on and im not able to start the self kleen he tell me close the door
Hello there and welcome to Fixya Ok here is the thing about the self clean features on these ovens the self clean feature is programmed in the ovens computer memory so when ever the self clean feature has been interrupted it needs to be reset The only way to reset this is to first unplug the oven and leave it sit for at least 1 hour (without interruption) now after the full hour is up plug in the oven and you may hear a audiable beep if so simply press the cancel button and you should be able to nw open the door or get back to what you were trying to do ok ?So please try this and post me a comment on how this works if there is more help that is needed i can continue to help you on this ok?Best regards Michael
10/6/2013 4:12:55 PM • KitchenAid... • Answered on Oct 06, 2013
KitchenAid KGSA906PSS Gas Kitchen Range Logo
149 questions posted
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
no power touch pad kitchen aid
  • Kitchen Ranges
