20 Most Recent
KitchenAid KERC700LBS Electric Kitchen Range Questions & Answers
Broiler element sparked fire, is the oven safe to use?
any food with an oil base will catch fire on a heating element, it will be fine to use but try to keep food from spilling out towards any heat source, use a try to collect any food drippings or a tray with vents if doing potatoes this will minimize any food dripping on the elements. it will smell for a while on the first cook as the oil will still be present on the element but it will soon burn off.
Latch not locking when selecting self cleaning
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%%%%%%
Self cleaning does not work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
