20 Most Recent Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Questions & Answers
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Kenmore 79012 /... | Answered on Jun 19, 2018
Temperatures vary for two main reasons, component tolerances and positioning of the sensor.
Kenmore 79012 /... | Answered on Feb 15, 2018
first you must wait until the safety door lock un lockes this will happen after the oven has cooled off
Kenmore 79012 /... | Answered on Jan 07, 2018
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Kenmore 79012 /... | Answered on Dec 27, 2017
The burner is not level ,or you need to adjust the air flow on the end of the burner.
Kenmore 79012 /... | Answered on Dec 08, 2017
The F90 error code is a door lock code. There are a couple of steps that you can take to try and clear the code. Do the following:
1) Unplug the range and wait for one minute.
2) Plug the range back in and turn it on.
3) Hold the door in and start a self clean cycle.
4) Wait for 2 minutes and then cancel the self clean cycle.
5) Do not let the door go until the door lock light goes out.
If that procedure does not clear the error code then you may have to get a Kenmore repair tech to take a look at the unit. There are a number of electronic fixes mentioned in their repair manual, but you would have to have the proper tools and training to run through those procedures. If there is any warranty left on the unit you can of course have the repair paid for. If not, then any repair shop should be able to give you a rough estimate on the cost of repair.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Kenmore 79012 /... | Answered on Nov 23, 2017
i found this on the internet..
For a regular electric oven: Place a bag of ice directly on the melted plastic to chill it and make it more brittle. Then carefully, using a razor-blade scraper, lift off the puddle ofplastic. This procedure will not hurt an interior porcelain finish. For a regular gas oven: First turn off the gas..
plus you could go to this link if you need more help..
Cleaning melted plastic from oven Google Search
Kenmore 79012 /... | Answered on Oct 27, 2017
Sounds like it is dangerous. Get a gas engineer to repair it.
Kenmore 79012 /... | Answered on Oct 15, 2017
Could be an open fuse or loss of power at the outlet.
Kenmore 79012 /... | Answered on Jul 28, 2016
door doesnt completely close when baking with kenmore elite 7903670 very frustrating
Kenmore 79012 /... | Answered on Jun 26, 2016
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
605 questions posted
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
kenmore model 790 78868800
  • Kitchen Ranges
