Black Line along center/right edge.
What can be done to solve this?
First, the line are in all printing pages, or only when you make copies?,
if the line are in all printing pages, maybe your fuser has damage the fuser film sleeve,(aprox, 10-20 dlls), if only this line are when you make copies, maybe the glass in the scanner are dirty(clean and try).
i expect this solution your problem
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
