SOURCE: ONLY HD2 works, which is used most of the time.
I would look to see if a set up menu on the set has the other inputs lock out.
SOURCE: We lost picture (no picture) through cable portal.
hyperunit failure. that tv uses whats called a " next hyper-unit" it is the digital scan card for the tv. it does the video and audio processing for the tv. they can be very heat sensitive and get better ot worse over time. the repair is very involved i suggest calling a repairman.
SOURCE: 3"X2" HD) radio by Insignia Radio
I'm assuming that you have tried to reset the radio with the button on its side and it didn't work. In that case this isn't a software - or commands - problem that can be fixed with owner commands, it's hardware: the processor of the radio got stuck because its firmware got corrupted.
All you can do is to force a complete reboot: with the radio working disconnect the battery; join the battery pin connectors for an hour to discharge all residual electricity from it (use a small piece of tin foil); plug it back - if the processor is still operational and the firmware chip intact the full reboot will take place and the radio should start functioning correctly. If this doesn't happen then the radio has failed - not worth repairing, just get a new one.
SOURCE: Possible to copy hd1 to hd2 (and copy the windows etc at the same time)
in windows 7 yes it's possible.
