20 Most Recent Sanyo Xacti VCP-HD2 Camcorder Questions & Answers
3answers
Mp4 player
I have the HD2. I have to install code pack called CCCP to play my video on my pc. It's come with a Zoom player too. http://www.cccp-project.net/download.php?type=cccp
1/11/2022 3:24:17 AM • Sanyo Xacti... • Answered on Jan 11, 2022
0answers
4answers
How do I recover my deleted photos and movies?
Hello, henryrich874! You can try this photo recovery software (also recover music and video files); it can help you recover your lost photos and movies from your Sanyo Camcorder: Photo Recovery for Windows Users Photo Recovery for Mac Users Remember not write any thing to the device until you have got your photos and movies back!Best wishes!
10/28/2013 1:48:02 AM • Sanyo Xacti... • Answered on Oct 28, 2013
Lcd on Video camera not working
take the LCD apart & look up the numbers on the back of it, order the part from were ever you find it form google & put the new one in urself when it arives, this will safe you @ least 100$ on someone else doing the same thing
2/11/2013 10:10:49 PM • Sanyo Xacti... • Answered on Feb 11, 2013
I have the Sanyou Model
There are a few things that could have gone wrong ..The first you may have fried it ..by using a larger voltage one ..and in this case you should see what is wrong with it ..Probably a fuse on the main board if you are lucky ..
Another thing ...the batteries could be damaged from the same cause..and now they can not keep the power and need to be replaced..
Or the plug was damaged cause you forced a wrong charger into it ..and in this case ..if you plug a charged battery ..it should work ..and you will know it is something wrong with the charging route ..and see what need to be changed.,.The plug ..maybe a wire being damaged..The main idea is even if they look the same ..and have the same plug ..the chargers are not the same ...they have differen voltage and amperage..and its not a good idea to improvise ..if it is just the battery ..it will power up with the original charger..if it do not ..I think you should have it seen by a professional ..at least to give a certain diagnostic and see if it is worth repairing or not ..
8/15/2011 4:47:15 AM • Sanyo Xacti... • Answered on Aug 15, 2011
Need instruction manual for sanyo xacti vcp-hd2
Assuming you mean the VPC-HD2, you can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/product/Downloads/VPC-HD2_OM_English-6327393.pdf
6/1/2011 9:20:49 PM • Sanyo Xacti... • Answered on Jun 01, 2011
I need a manual for digital movie camera/sanyo
This is your manual.
Sanyo VPC-HD1AEX VPC-HD1
https://dmc.wisc.edu/images/EFLmanuals/sanyo_xacti_vpc-hd1a.pdf
You can download it from above link.
Regards.
4/9/2010 10:49:07 PM • Sanyo Xacti... • Answered on Apr 09, 2010
Put camera in cradle to charge. red light comes on
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
10/15/2009 2:34:43 PM • Sanyo Xacti... • Answered on Oct 15, 2009
2answers
USB device unknown
Make sure you are connecting directly to the computer's USB port, not through a hub. Try disconnecting other USB devices before plugging in the camera. Check the manufacturer's website for updaded drivers: if all else fails, a reinstall of the camera's drivers may be in order.
2/14/2009 6:09:10 PM • Sanyo Xacti... • Answered on Feb 14, 2009
Sanyo HD2 is now very slow to start-up & switching between modes
Dear FixYa,
Thank you for your email asking whether I had received a solution to the problem I posted yesterday on your company's site.
I have not had any response to the problem I posted and will think about your offer to solve the problem for the fee you mentioned in your message.
I have had trouble finding your email address as the return address you left says 'do not reply', nevertheless I feel you may get this messasge by some means, perhaps someone in your company will pass it on.
Thanks again for your mild interest.
Yours sincerely,
text me with a solution.
+07879023247
1/6/2009 2:57:10 PM • Sanyo Xacti... • Answered on Jan 06, 2009
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
1/4/2009 6:38:13 PM • Sanyo Xacti... • Answered on Jan 04, 2009
Sanyo Xacti HD2 Flip Flash Not flashing
Hmm...I can't find a software control either. When the flash is down there is a cross through the lightening mark in the upper left portion of the screen, and when I press the flash button and raise the flash the same lightening mark in the upper left has no cross through it. Do you have the same mark? Does the flash button have no effect upon the mark?
1/4/2009 4:05:12 PM • Sanyo Xacti... • Answered on Jan 04, 2009
Black screen
Try removing the battery and putting it back in again. This happens to mine. Also make sure that the SD card is fast enough. I.e. a 40x SD or more card or a class 6 SDHC card.
1/4/2009 3:58:17 PM • Sanyo Xacti... • Answered on Jan 04, 2009
2answers
How do I fade in and out with the xacti?
on Xacti HD2 "menu" button doesn't respond in Recording mode... any suggestions?
1/4/2009 3:56:36 PM • Sanyo Xacti... • Answered on Jan 04, 2009
I need an "activation code" from Corel to complete the installation
Perhaps your camera only comes with a trial or limited edition of the software. Try proceeding without the activation code and/or read through the camera's documentation very carefully.
3/1/2008 12:12:30 PM • Sanyo Xacti... • Answered on Mar 01, 2008
Upload
Well, There is an extra cord that connects to the computer and the camera, I don't know the exact name of this But If you have this and are needing help with that, a pop up from your computer should come up saying "Input device" and you should be able to do it there easily.
11/29/2007 8:41:44 AM • Sanyo Xacti... • Answered on Nov 29, 2007
Problem with memory card
What model Sanyo camera? What type and size memory card? Just what problem are you encountering? Is there an error message?
10/15/2013 10:53:57 PM • Sanyo Xacti... • Answered on Oct 15, 2013
My waterproof sanyo camcorder is not working
Just let it dry in room temperature for a day. Then try switching on. If it still doesn't work take it to a store.
10/30/2012 3:53:03 PM • Sanyo Xacti... • Answered on Oct 30, 2012
Sanyo VM-EX220P 8mm Video Camera. Hello my camera won't play any of my cassettes. It all comes up scrambled?!
Question edited for a lot more clarity. Question moved from Televisions category. When was the last time the head was cleaned? It may also need servicing or Adjustment.
Sanyo VM-EX220P Adjustment Manual
https://www.manualslib.com > ... > VM-EX220P View and Download Sanyo VM-EX220P adjustment manual online. 8 mm. VM-EX220P camcorder pdf manual download. Also for: Vm-ex370p, Vm-ex280p. ..
6/26/2023 6:37:46 PM • Sanyo Video... • Answered on Jun 26, 2023
Sanyo Xacti VCP-HD2 Camcorder Logo
Popular Tags
26 questions posted
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
recover deleted photos movies
  • Video Cameras
