Lands Phones Logo
P
PDUK Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In Calendar Creator 12, How do I change the date format from US mm/dd/year to UK dd/mm/year?
Stan Naramore
Level 3:
Guru:
  • Master 531 Answers
  • Posted on Jan 22, 2019
Stan Naramore
Master
Level 3:
Guru:
Answers
531
Questions
Helped
209000
Points
2468
Have you tried setting the Country drop-down Menu to a country that uses the format you want?
Testimonial: "Thanks for the suggestion, but there is no Country drop-down menu that I can find on CC12."
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Nov 19, 2007
SOURCE: Date format in quickbooks 7.4
If it's anything like Excel, someplace in the FORMAT menu should be options to allow you to change the date format. (Block off the cells, row, or column in question, click FORMAT in your toolbar.) You may have different country options or formatting choices within the date type.
Anonymous
  • Posted on Jun 27, 2008
SOURCE: Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
Anonymous
  • Posted on Nov 07, 2008
SOURCE: Date format changed!
when all else fails, read the instruction manual carefully
Anonymous
  • Posted on Oct 26, 2010
SOURCE: in quickbooks pro 2007, the date format is mm/dd/yyyy
Hi, i am using windows 7 and clicked on start, control panel, regional and language, and then found my settings (was having same problem with quickbooks premier and the date set to US) and found i had accidently selected in the install of windows 7 [English-USA] instead of [English-Australia]. i altered two settings and now my quickbooks is working fine. whenever i searched for this on quicken help sites it did not indicate clearly how easy it was to fix this.
1helpful
I want to know when on my mobile phone it asks my date of birth and when entered says it wrong i think i should know when i was born
It seems like you are not entering it in th right format like:
DD/MM/YYYY which mean two digits for the two for the month and for the year 01/01/2015 now this is just one example there many different formats like yyyy/mm/dd mm/dd/yyyy mm.dd.yyyyy and so on
Mar 11, 2015 • Cell Phones
3helpful
2answers
My Nokia E5 is set by default to daylight saving mode, but it is canceled this year in Egypt, so I need to uncheck the auto adjust daylight saving but I cannot.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select OFF, the phone will NOT
automatically update the date and time.
I'm not understanding how to change the date in the date worksheet on the BAII. When I enter the numbers and (enter), I get and error 6. Any suggestions on what I'm doing wrong?
Error 6 indicated an invalid date, such as a month greater than 12 or a day greater than 31.
The calculator has two different formats for dates: DD-MM-YYYY and MM-DD-YYYY. To see the current format, press 2nd [FORMAT] down-arrow down-arrow. To change the format, press 2nd [SET]. Press 2nd [QUIT] to exit.
5helpful
2answers
My LG KS360 phone has developed a date fault since 1 Jan 2011 whereby it is saying 32/83/2010. I cannot fix it. Please advise.
Noticed the same problem today. The "set date" option wouldn't let me reset the day, month or year to anything sensible. Changed the date format to MM/DD/YYYY (it was previously DD/MM/YYYY). Then it let me set correct month, day and year. Reset the date format back to DD/MM/YYYY and it's still correct (and will now let me change it while in this format). Don't understand it, but seems to have fixed the problem. (Guessing it was something to do with 2009 changing to 2010??). worked for 2011 also.
Jan 02, 2011 • Cell Phones
Setting up date and time
Please check the date display format
In your mobile it might have set to this format
MM DD YYYY
So as the first column is in months as you enter 24 it doesnt accept and shows 02 ,This is because you have only 12 months in a year.
So please type month date and year.
If you want you can change the format to DD MM YYYY in date and time setting option.
Thanx
Thanx
Settings on the date and the year
To Set the date:
1. Press the Up/Down button to enter the Set Date option.
2. Press the OK/MENU button.
29
3. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
4. Press the Up/Down button to set the Date and Time digits.
5. Select the first option of the Date format and press the Up/Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
8helpful
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
list below:
Auto update - Select On, the phone will
Jan 03, 2009 • Cell Phones
Setting the time
Go to Settings ---> date and time
Set date format: MM/DD/YY or DD/MM/YY
Set date: Day / Month / Year
Set time format: 12 Hr / 24 Hr
Set time: Hour / Minute / Second
5helpful
Setting date/time
Press the calendar/clock button
Hold the M+= button until the first digit of the date/time begins to blink
Set the time using this format- hh:mm
Set the date using this format- dd:mm:yyyy,
July 15, 08=15:07:2008 (I got this step wrong thinking the format was mm:dd:yyyy)
Press the M+= button again.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
