20 Most Recent Vivitar Vivicam 8225 Digital Camera Questions & Answers
You don't need the Vivitar software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Vivitar Vivicam... | Answered on Aug 03, 2012
Press the M button to bring up the menu. Use left/right-arrow to select the wrench icon. Use up/down-arrow to select "Date" then select "Set Date."
Vivitar Vivicam... | Answered on Jul 30, 2012
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Vivitar Vivicam... | Answered on Jul 15, 2012
The 5022 is primarily a still camera, with some video capabilities grafted on. As such it records images not sounds. You can add a soundtrack using video-editing software on a computer, but you cannot record one on this camera.
Try the procedures in this tip.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as PIcasa.
Vivitar Vivicam... | Answered on Jun 07, 2012
Make sure the camera is not in macro mode. See page 18 of the manual.
Vivitar Vivicam... | Answered on Mar 20, 2012
Make sure the macro/far setting is set appropriately. This will affect the sharpness of the pictures, and the flash will not work in macro. See page 18 of the manual.
Make sure the macro/far setting is set appropriately. See page 18 of the manual.
Press the MODE button until a right-pointing triangle in the upper-left corner indicates playback mode.
Full details are in the "Playback Mode" section beginning on page 37 of the manual.
Vivitar Vivicam... | Answered on Mar 01, 2012
Press the MODE button until the right-pointing triangle in the upper-left corner indicates playback mode. Full details are in the "Playback Mode" section beginning on page 37 of the manual.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Yes. Bear in mind that not all computer USB ports put out enough current to charge batteries. Don't use a hub, but connect directly to the port.
Use mode button then select movie. Shutter button starts and stops movie taking. Need 4 gB SDHC to get long movie taking.
Vivitar Vivicam... | Answered on Feb 18, 2012
To focus on your subject, lightly push the shutter button (the button you use to take pictures) only half way down. When you push the shutter button half way down, this auto-focuses the camera and you can then fully press the shutter button to take your picture.
Vivitar Vivicam... | Answered on Sep 01, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
Press the OK/MENU button in the center of the cursor pad to access the main menu. If you need a manual, you can download one from the manufacturer's web site at
http://www.vivitar.com/files_products/14/ViviCam_8225_Camera_Manual.pdf
Vivitar Vivicam... | Answered on Aug 17, 2011
Vivitar Vivicam 8225 Digital Camera Logo
69 questions posted
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
down load install software vivitar
  • Cameras
