Garden Logo
Tom Wey Posted on Jan 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Riding lawn mower starts but keeps reving up - Garden
Matthew Minton
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Jan 21, 2019
Matthew Minton
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
32149
Points
160
Sounds like choke is sticking try and clean it with some carb cleaner
Testimonial: "Thank you. I used a carb cleaner and it now works fine."
5 Related Answers
Dwain Pippen
  • 377 Answers
  • Posted on May 15, 2009
SOURCE: murray riding lawn mower
Nix on safety switch. If it was a safety switch, you would not hear a click when you turned the key to start.. There would be no power going to the solenoid. However, if your engine has the fuel shutoff solenoid beneath the carb bowl, it will make a faint click when you just turn the key to the 'on' position. Probably as thabrain says, a bad solenoid.
Anonymous
  • 246 Answers
  • Posted on May 17, 2009
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Anonymous
  • 73 Answers
  • Posted on May 28, 2009
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Anonymous
  • Posted on May 31, 2009
SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
Anonymous
  • 10865 Answers
  • Posted on Jun 02, 2009
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 • Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 • Garden
How do i dis engage the safety device?
It's not recommended but find the switch you want to bypass should have two wires going all the switch does is make a connection to send the power to start the mower or to keep the circuit going to keep mower running
Needing to know how to keep the riding lawn mower running?
Can you tell us what the model of the engine is that is on that unit?
Aug 19, 2017 • Garden
Keeps shutting off. Do riding Lawn Mowers have alternators?
sort of they have a stator under flywheel that charges battery. if your carb has an electric solinoid on it it need voltage to stay open but that is supplied by battery. solinoid works by key switch.switch could be bad ,solinoid could be bad ,could have fuel feed problem or spark problem need more info how long does run? does it start right back up?ect hope this helps
1helpful
My john deere riding mover the clutch will not disengage it still keep going.any solutions
With the engine OFF, reach underneath and locate the plug for the blade clutch and unplug it. Start up the mower and see if the blades are turning. If they are still turning with the clutch unplugged, REPLACE THE CLUTCH
1helpful
Reving too high dosent idol
If the mower is reving up and down it sounds like a carb issue it most likely needs rebuilt and adjusted I would also change the air filter on it after you get it repaired to help keep the carb clean.
Top Garden Experts
Jay Finke
Jay Finke
john h
