Measuring Tools & Sensors Logo
J
Joyce Wortham Posted on Jan 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Outside temperature not working on ACU RITE how do you correct?
Cherwally
Level 2:
Sergeant:
Habit-Forming:
  • Expert 156 Answers
  • Posted on Jan 20, 2019
Cherwally
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
156
Questions
Helped
62204
Points
619
Read the answer on the same question where you written the model as well
5 Related Answers
Anonymous
  • Posted on Jun 10, 2009
SOURCE: How to set the time on Acu-Rite model 13100 clock?
How do reset time on model 13003 ?? It reads 12:15 and the Time is 11:27 Clark page [email protected]
Anonymous
  • Posted on Nov 15, 2009
SOURCE: Acu-rite atomic clock squeaks periodically, why?
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real solution, but here is the explanation:
Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit’s ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Anonymous
  • Posted on Dec 01, 2010
SOURCE: My acu-rite keeps beeping even after a battery
I cut the wire that leads to the annoying noisemaker. Carefully remove the rear cover to expose the circuit board (the rear cover is connected to the circuit board so pull them apart carefully). Locate the noisemaker, mine was round and connected to the back cover with black and red wires. Cut the black and red wires and replace the rear cover. NOTE: If you use the alarm feature, it won't work anymore. I read on the Acurite site that the reason it beeps is because of interference with the wireless signal. They suggest not using one of your wireless devices. If you are like me, that isn't a good option.
gusgelpi
  • Posted on Feb 03, 2011
SOURCE: I need a manual for
Here you go. May not stay up forever. http://www.weatherconnection.com/manuals/00592W.pdf
fixya-surfer
Sys Admin
  • 73 Answers
  • Posted on Mar 02, 2011
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Outside temperature not working on ACU RITE Model 754W2 how do you fix?
The outside sensor seems is not connected.
Maybe low baterry?
Need manual for accu-rite 00592TX
My outside gauge went flying off my porch in a gust of wind. I found everything but the back that covers the batteries. Can I get a replacement back?
3helpful
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Top Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
