20 Most Recent
Acu-Rite Acurite Wireless Weather Thermometer 604 Questions & Answers
I have an Acurite 822-RX thermometer that shows HH
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
My acurite inside unit keeps
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
I have this model and the outdoor temp sensor isnt
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
How do I set the Clock on my Acu-Rite 00604RX
Hi Mona,
To set the time on your 00604 thermometer.
Press and Hold the Time button until the Hour begins flashing.
Release Time
Press and Release the + or - buttons to adjust
Press and Release Time and the Minutes will flash
Press and Release Time to lock in your setting.
