20 Most Recent
Acu-Rite AcuRite 00592A2 Wireless Humidity and Temperature Meter Questions & Answers
Need manual for accu-rite 00592TX
My outside gauge went flying off my porch in a gust of wind. I found everything but the back that covers the batteries. Can I get a replacement back?
I have an ACURITE 00590A1-RX.
From the manual, such as it is:Set the Time Manually:If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, dateThis works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
I have an acu-rite 592w
I know this thread is old, but I see no one answered the question - "How to remove the stand"
Grab the stand on the sides with your thumb on one side and fingers on
the other and pull down ... I had to "rock it out" or pull one end then
the other. It seems stuck but it will come off ... Another option would
be to take a small screwdriver and insert it in the small openings under
the standard gently push the tabs while pulling down on the side you
are doing. Push the tabs towards the outside of the unit not the inside
... in other words if you are working on the left hole push left (left
while viewing from the face of the unit)
