20 Most Recent Robinair Cool Tech 34700Z Recovery, Recycling, Recharging Questions & Answers
Check oil drain solenoid for any debris or damage inside the solenoid flunger. Replace/rebuild as needed. Hope this will solve your problem. Don't forget to vote for my solution
Robinair Cool... | Answered on Jun 11, 2019
If you have less than 10lbs of refrigerant in the tank and you're changing modes, this can happen. If this is the case, Tech Support can help walk you through a reset process at 800.822.5561
Robinair Cool... | Answered on Jan 29, 2019
Please be informed that, one code can be use only one time! However now i will give one more new code: 6FAAC95001. Apply it now and solve the problem!
Don't forget to vote for it, if you wish to get help in future. Good luck....
Robinair Cool... | Answered on Feb 22, 2018
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Robinair Cool... | Answered on Feb 15, 2018
You have run the machine 10+ hours for vacuum since last oil change. so you have to change vacuum pump oil. For change vacuum pump oil just follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL'' then press "YES" key. Now vacuum pmp will run for two minute & stop automaticly. When pump stop you just open the oil drain plug & oil fill cap of vacuum pump ( Located oute side of the machine near high & low side hose ) & drain all oil from vacuum pump. After draining used oil,replace oil drain plug & fill new ROBINAIR vacuum pump oil till middel of sight glass.Press "YES" key & follow on screen messeage. NOTE: Do not over fill the pump & Do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
Robinair Cool... | Answered on Aug 15, 2017
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
Robinair Cool... | Answered on Jul 24, 2017
I would be very careful releasing refrigerant from the liquid side of the tank as suggested earlier. Knowingly releasing R134 into the atmosphere carries very large fines if you get caught and is very environmentally irresponsible.
Robinair Cool... | Answered on Jul 09, 2017
Phone the agents for the answer.
Robinair Cool... | Answered on Jun 07, 2017
Try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution
Robinair Cool... | Answered on Jun 02, 2017
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Robinair Cool... | Answered on Nov 17, 2016
You confirm it by how it functions, if it sticks in a mechanical way there is no electrical testing that would be valid. I would just replace both solenoids.
Robinair Cool... | Answered on Oct 13, 2016
Disconnected Air Purge lines. It was under high pressure (careful).
Robinair Cool... | Answered on Jul 12, 2016
This is a common problem of Robinair 34700Z / 347002K & 347112K series machine. So don't worry just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full, carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify if there is high pressure in the ISV tank. Purge excess air from the tank manually. (Open air purge hose from the ISV tank, then carefully press tank valve as needed to blow out excess pressure from the ISV tank)
After doing all above stapes and your problem still exist then replace air purge solenoid (Air purge solenoid located near the ISV tank and fixed with automatic air purge device). Hope this will solve your problem, if so please vote for it for farther help! Good luck
Robinair Cool... | Answered on Jul 22, 2015
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
366 questions posted
Top Robinair Measuring Tools & Sensors Experts
Sheldon Dedek
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Robinair Measuring Tools & Sensors
Most Popular Question
will robibair 34700z not inject oil
  • Measuring Tools & Sensors
