20 Most Recent Mitutoyo 500-672 0-6" ABSOLUTE Digimatic Coolant Proof Inch/Metric Caliper Questions & Answers
Hold the origin button for greater than 1 second. You may need to use a point tool to push the button all the way down.
Mitutoyo 500-672... | Answered on Jul 04, 2019
These 2 signals are drive prohibition (overtravel) inputs in forward and reverse directions. If Drive Prohibition Input Setting (Pn504) is 1, you can use the setting of Stop Selection (Pn505) to select the operation to be taken upon input of each prohibit signal. If Drive Prohibition Input Setting (Pn504) is 2, drive prohibition input protection (E380) actuates upon input of a drive prohibition.
Mitutoyo... | Answered on Mar 02, 2019
I realise this question is old, but you never know, might help someone in the future. This particular error is that the probe is not correctly seated, usually the magnets have become slightly loose. The solution is to take the probe head off the cmm, and push the magnets against your surface table or suitable flat surface, this should push the magnets into their correct position. If this doesn't help, it may be that you've managed to break that particular part, if you have a probe rack, try a different probe. Lastly, if you crashed the CMM by hitting something, ensure you didn't bend your probe in the process (and the ruby is still there!), this doesn't help the error code fix, but worth checking as the cmm crashing into something at speed is the most likely cause of this E671 error.
Mitutoyo... | Answered on Sep 01, 2017
Mitutoyo 500-672 0-6" ABSOLUTE Digimatic Coolant Proof Inch/Metric Caliper Logo
Popular Tags
3 questions posted
Top Mitutoyo Measuring Tools & Sensors Experts
mikenearman
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Mitutoyo Measuring Tools & Sensors
Most Popular Question
readout flashing series dash marks
  • Measuring Tools & Sensors
