SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
Figure 2: Removing the rear access door
Preventing paper jams
The following information will help prevent paper jams from occurring:
SOURCE: Need software to install HP OfficeJet T45 printer to my Vista PC
I had the same problem, but was able to use my printer by adding HP OfficeJet V40 instead from the dropdown list. I didn't need to bring in a driver. Try it...it worked for me.
SOURCE: Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
SOURCE: HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
