SOURCE: faulty door which keeps beeping
I had a similar problem which was resolved by replacing the door interlock switch (cost about £10.00).
To get to it you need to disconnect the mains then remove the top lid. You can then see it by looking down the inside to the right. Remove the 2 screws inside the door opening and you can then lift it out after disconnecting the wiring plug.
Replacement is the reverse of the above, a 5 minute job.
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
SOURCE: My Bosch washing machine (WFX145SGB
Eventually discovered that if the 'start' button is held down for a few seconds it unlocks the 'child lock'.
SOURCE: I have a bosch classixx 6 1200 express washing
My Bosch washing machine is showing a key symbolt, is beeping and flashing shows O and will not let me start a new cycle.
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
