Washing Machines Logo
I
Ivonne Sherman Posted on Jan 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung wf42h5200aw/a2 front loading washer gets stuck between the rinse and spin cycle over and over again for hours. Every part as been replaced. Anyone else having this problem?
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Jan 09, 2019
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
741850
Points
5402
Did you replace the timer?
2answers
Samsung washer # wf42h5200aw/a2-01 will not agitate or sping
check belt if ok possible cogs under agitator to tub
Front load washer spins and rinses but won't wash!
The pump could either be broken or clogged for your washing machine.Or the drain hose is broken or clogged or the switch assembly is not working anymore. A person that fixes washing machines would need to take a look and see what the problem is.
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
1helpful
The wash cycle take a very long time. It repeats cycles. It's balanced, cleaned and the drain pipe is set correctly.
Verify the door switches are activating correctly. If it senses the cycles are interrupted, they could be repeating. See if you have any codes. Check your codes in the manual. Your manual will also instruct you how to check for codes. It is very simple.
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
2answers
Samsung Front Load washer stops in the rinse-spin cycle.
Many washer have two pumps in them. One circulates the water, the other is the drain pump. You may be hearing the circulating pump.
Why Dont I have enough water in my washer when washing?
The water level switch works off water pressure at the tub fills. The switch, or the tubing connecting it to the tank may need to be replaced.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
