Have you tried hitting the input button and see if your on Ant1 Ant2 Air ect ,cable ect ?
SOURCE: Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
SOURCE: Olevia Kolin PT-501 LCOS TV Screen remains black and lights flutuate
I have the same TV and had the exact same problem. I had to replace the lamp and power supply in mine to get it to work. Unfortunately...its next to impossible to find the parts, at least the power supply. I found the lamp online and I was lucky to get the online store I purchased the TV from to send me a power supply from one of thier stocked models, but only after I turned them into the FTC Consumer Protection. The TV was sold to me as a closeout but new, as it turned out the tv was a refurb, thats the only way I could get the parts I needed.
Hope this helps and if you need any other information please let me know.
T
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
SOURCE: My Sceptre X32GV-Komodo got a problem recently: I
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at [email protected].
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
