20 Most Recent DISH Network 322 DTV Receiver Questions & Answers
2answers
Screen "blinks" black every few minutes - Dish Network
Hi, Mary with Dish Network Customer Service. When the picture alternately goes from normal to a black screen, it is an indication of an intermitten signal issue. You can attempt to reset the receiver box by unplugging it from the power for 10 seconds and letting it reboot. Hopefully this will resolve your issue.
12/2/2023 6:11:15 AM • DISH Network 322... • Answered on Dec 02, 2023
How do you fix a black screen for a dish tv
I can definitely provide some assistance and get some steps to try to fix this. To ensure I get the correct steps, how long ago did this start? Does anything come up on the screen when you try to change the channel? Was anything changed in the install? When you turn the TV off, then on, does it say an input or a channel?Tommy FaustDISH Social Media Representative
4/27/2022 8:14:27 AM • DISH Network 322... • Answered on Apr 27, 2022
Black screen and no sound no menu no anything after remote hit
test with another remote. buy a cheapy remote at dollar general and see if you can connect it to the tv with code number code numbers on internet
7/31/2017 5:31:44 PM • DISH Network 322... • Answered on Jul 31, 2017
2answers
I want to add a dishnetwork 311 receiver to my
I recommend it as the receiver may be non functional for sometime before you receive a new one. Another point to consider is if you purchase a receiver on E-ay there is a good chance that that receiver may have an ooutstanding balance to dish owed by its last owner which will make it useless to you unless you want to pay the bill. 311 run about 99.00 from a reputable dealer and would advise you to pursue that avenue. Thanks for using Fix Ya.
1/17/2017 6:24:40 AM • DISH Network 322... • Answered on Jan 17, 2017
Will dish network 510 receiver work in uhf with dish 21.1 remote
No, the 510 receiver does not have a UHF input. http://manuals.solidsignal.com/DVR510.pdf You can upgrade to a 512, 612, 625, but would need your installation upgraded to be compatable (Dish Pro to Dish Pro Plus).
4/28/2015 10:07:59 PM • DISH Network 322... • Answered on Apr 28, 2015
How to set up a dish network
mellow_boy2k,
If you want to have DISH Network service, you can call 1-800-333-3474 to talk to our Sales Department. They can provide you with our different programming packages, receivers, and options required for our services. If you qualify, there is a 24 month commitment associated with our service. Please call the number above for more information. I have also provided a link to our Website.
http://www.dishnetwork.com/
Ray Calo
DISH Network
10/6/2014 6:21:11 PM • DISH Network 322... • Answered on Oct 06, 2014
How to connect dish 211z to manual dragout dish
Refer its user manual for details. http://electronicshelponline.blogspot.com/
6/28/2014 6:28:23 PM • DISH Network 322... • Answered on Jun 28, 2014
How to install a dish 211z
Contact the service provider. It will be best. Electro help
6/28/2014 6:17:40 PM • DISH Network 322... • Answered on Jun 28, 2014
Dish Network "No Signal" Message on Screen..Standby Mode
austinbrooke,
I saw your post and I'm wondering if you are still having problems getting a picture on your TV. Is it TV 1 or TV 2? What type TV is connected? If it's a HD TV, you will need to go through your input or source list on the TV to find your picture on TV 1. TV 2 is generally on either channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
6/17/2014 10:32:57 AM • DISH Network 322... • Answered on Jun 17, 2014
Just intalled system to new tv. the dvr works but i am not getting a signal
If you're sure everything is connected correctly check your tv input, there is a special input channel for each cable. FOR TV1: RCA: input 1,input2,video 1,video2, if you're using a coax cable: channel 3 or 4. If the problem is on TV 2 you're using a coax cable and it has to be on channel 60 or 73. For a wiring diagram you can visit the official dish website (it's on your bill) & visit the technical support page. This link is for tv1, you will also find the steps for tv2 Black Blue Or Snowy Screen TV1
5/27/2014 3:22:16 AM • DISH Network 322... • Answered on May 27, 2014
Desconecte una caja doble de dish y ahora uno de
Hola Jorge, disculpe la demora en responderle, quizas en este momento ya no necesite la respuesta para este problema pero me gustaria proveerle los detalles de todas maneras por si en futuro necesita ayuda esto le pueda ayudar. Este problema lo puede ocasionar distintas razones. El primer paso a tomar es: Por favor verifique que luces estan prendidas enfrente de su receptor. Bajo donde dice MODE la luz debe de estar en DUAL (2 cajitas) si esta en SINGLE, abra a puerta enfrente del receptor, oprima el boton que dice 'Mode' para poner el receptor en DUAL. Si este no es el proble may esto no lo arregla necesito que en el cuarto del televisor numero 2 (donde NO esta el receptor) usando el control que vino con la TV cuando la compro que ponga la Tv en el canal 60 si tiene una imagen necesito que agarre su control de DISH y en el control oprima el boton de SAT (el cual se encuentra en la parte de arriba a mano izquierda) una vez haga esto, trate cambiar canales. Si esto no funciona, otra vez con el control original de la Tv trate de poner la Tv en el canal 73. Si le sale una imagen, agarre el contriol de DISH, oprima SAT y trate de cambiar canales. Si lo recien explicado no le funciona, valla a la TV 1 otra vez. Con el control 1 en mano Oprima Menu y una vez tenga el "Menu Principal" en la pantalla Oprima el numero 6, espero dos segundos y oprima el numero 1, espero otra vez dos segundos y oprima el numero 5. Este proceso lo lleva a una pantalla llamada 'Modulator Set Up' En esta pantalla donde dice 'TV 2 OUT' bajo 'Channel' que numero de canal tiene? 73 o 60? Basado en el numero valla al cuarto de TV 2 y usando el control que le pertenece a la Marca de TV (no el control de DISH) ponga la Tv en ese canal. Esto tambien debe de resolver el problema. Si necesita asistencia con su servicio de DISH sientase libre de contactarme a: [email protected]Kimberly.EscobarSocial Media RepresentativeDISH L.L.C
10/10/2013 8:44:13 PM • DISH Network 322... • Answered on Oct 10, 2013
Dish reciever no tv2 light
Schueller143,I would be happy to provide information on that. The TV2 light will only turn on when the TV is in use. If you pickup the TV2 remote, and press the select button, the light will turn on. If you're experiencing a problem viewing the TV2, just let me know!Tommy FaustDISH Social Media Representative
4/12/2013 5:56:26 PM • DISH Network 322... • Answered on Apr 12, 2013
I HAVE DISH NETWORK RECEIVER #322 AND ON TV 2 I
Hello! My name is Becki Barned, and I am from Dish Network customer service. The problem that you are having is simple to fix. Although your remote works for the volume, and power, it is not working for the satellite. It does need to be reprogrammed. Just take it to tv1. With your tv1 remote, press the menu button twice. Then with the tv2 non-working remote, hold down the SAT button until all the mode lights light up at the top, then release. Then press the #9 on the remote keypad, then the pound (#) button, then record (above the number 3 on the keypad) 3 times. This should resolve your issue!!! If not, you can blog back, or find us on Twitter!!!!
12/13/2012 10:47:20 PM • DISH Network 322... • Answered on Dec 13, 2012
I need the diagrama for a322 dish
I would be more than happy to help you, oroblanco24k.Here is a link to a diagram on how to run a line from the receiver to the TV via Coax. http://www.mydish.com/support/receiver-tv1-coaxTo access additional diagram go to this link http://www.mydish.com/support/ . Once there select Technical Information > Receivers > Diagrams. If you need additional assistance, just let me know here! Tommy Faust DISH Social Media Representative
11/20/2012 5:20:20 PM • DISH Network 322... • Answered on Nov 20, 2012
Smart is not put in right this is message error
joann edwards,I hope this has been resolved by now, but if now I would be happy to provide assistance! It sounds like the smartcard may need to be updated with our recent G3 model which is purple. If you can send me an email at [email protected] with the phone #, I would be happy to check this out further with you!Tommy FaustDISH Social Media Representative
8/29/2012 2:10:50 PM • DISH Network 322... • Answered on Aug 29, 2012
Is there anyone that.can draw me a diagram on reconnecting my dual receiver 322? i was sure.that i would remember how to connect the red diplexer to the seperator then all to receiver. i am so.techno
Hello amanda_ma714!Below are some links that should be able to help you in getting that setup! I am unsure the connection you're using, however you can browse around the link to get additional setups.TV connection: http://www.mydish.com/support/receiver-tv1-coaxThis link provides a brief setup from your wall to your receiver. Again I would recommend browsing around the link if you need additional info.Satellite connection: http://www.mydish.com/support/1-to-2If you have any questions or need further assistance, let me know here or at [email protected] and I will be happy to help further!Tommy FaustDISH Social Media Representative
7/19/2012 1:12:22 PM • DISH Network 322... • Answered on Jul 19, 2012
I disconected my receiver when connecting back did not work never acquire signal
The satellite in cables play a big role in a receiver getting signal. Since they were disconnected, verify the cables are both hand tight and everything is plugged in.If the satellite was working before, but isn't after disconnecting there may be a connection problem in the line. At that point verify all the cables are tight, and you can also try swapping the Sat In cables around. The Sat In cables have to be in the correct port to work. Let me know if the problem continues!Tommy FaustDISH Social Media Representative
5/24/2012 2:23:29 PM • DISH Network 322... • Answered on May 24, 2012
Join dish1000.2 with dish322receiver
Hi nganhoang54,A 1000.2 dish is mainly used on HD equipment to bring in the 3 satellites required. For a 322, the best choice of dish would be a Dish 500. To hookup a 1000.2 dish, you would need to point the dish, and run the line into a Diplexor. From the Diplexor side with one connection, run another cable into the single connection of another Diplexor, and from there one cable into a splitter for the Sat In connections. Take the TV2 Home Distribution cable and put it into the other port on the Diplexor, and connect TV2 from the open port on your first Diplexor.Let me know if you have any other questions!Tommy FaustDISH Social Media Representative
4/4/2012 1:33:13 PM • DISH Network 322... • Answered on Apr 04, 2012
DISH Network 322 DTV Receiver Logo
144 questions posted
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • DISH Network Televison & Video
Most Popular Question
use philips universal remote as second
  • Televison & Video
