20 Most Recent Hisense TL-3220 Television Questions & Answers
Hey Billy Lee,
If you're unsure how to unlock your TV, you may wish to check out Hisense's online documentation for the TL-2020 through the following link:
http://www.hisense.com/en/Support/download_manual.jsp
Instructions on how to disable any feature locks should be included in downloadable files on "page 9" and "page 10" of Hisense's support forums.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Hisense TL-3220... | Answered on Dec 23, 2016
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://electro-medical.blogspot.com/
Hisense TL-3220... | Answered on Jan 05, 2016
Check the fittings of audio output IC; to its heat sink. If it is loose, this kind of fault can occur due to IC overheat.
Gopakumar Gopalan Google
Hisense TL-3220... | Answered on Mar 26, 2014
that problem is usually cause of shorted fly-back transformer that give a very high voltage you can find that by hanging all secondary connection of fly-back then power it again then use your multimeter and range it to dc then ground the black prove to the body of your unit test the b-plus voltage if the supply is flickering it means your fly-back is shorted and if the supply is stable it means you have a shorted diode in secondary thank you
Hisense TL-3220... | Answered on Mar 05, 2011
The word ''no sync detected' means that there is no video connection between the cable box and the TV set. Isolate the source of trouble by connecting to the TV a prevoius video source that worked properly e.g DVD player. You should also try to get a new set of video cables as the ones you have may be internally broken.
Please follow the installation instructions carefully especially the colour codes of the video and audio cables i.e yellow cable to yellow connectors of TV and cable box , Red cable to red connectors of TV and cable box etc.
good luck!
Hisense TL-3220... | Answered on Oct 09, 2010
You have to find out if the remote is sending out the infrared signal to the TV remote receiver or not, you can test that by pointing the remote at the digital camera, you should see flashing light on the camera screen when any one of the remote button is pushed (digital camera can detect infrared light). If get the flashing light then the problem is in the TV remote sensor.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Hisense TL-3220... | Answered on Jun 15, 2010
follow the power cord to the board. that is the main power board. the capacitors are near the top center (aprox 3/16" diamiter and 5/8" long ) three of them. replace all three . firemarshel@yahoo
Hisense TL-3220... | Answered on Mar 08, 2009
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Hisense TL-3220... | Answered on Jan 14, 2009
Sounds like a loose connection somewhere.
Hisense TL-3220... | Answered on Dec 18, 2008
If your telly has no HDMI then I assume it mus have DVI instead. You can buy a DVI to HDMI adaptor from most good electrical stockists but the only problem is the financial one for the extra cost for the leads :-) Hope this helps.
Hisense TL-3220... | Answered on Oct 02, 2008
Televison & Video Logo
Popular Tags
35 questions posted
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
hisense lcd tl 3220 tv no hdmi
  • Televison & Video
