20 Most Recent Hisense TL1700 17 in. LCD Television Questions & Answers
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Hisense TL1700... | Answered on Jul 04, 2018
Replacing the Caps: won't do anything. Please do not waste your time, money and effort. The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Hisense TL1700... | Answered on Oct 20, 2017
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Hisense TL1700... | Answered on Aug 18, 2017
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Hisense TL1700... | Answered on May 05, 2017
Or, retire it to the great recycling center....
Hisense TL1700... | Answered on Mar 18, 2017
Which country are u in?
Most countries have shutdown their analogue TV now.
Hisense TL1700... | Answered on Oct 17, 2016
The TV must be in range of your wireless router in order for the TV to connect. You have to put the wifi password in the TV and sometimes the mac address of the TV into the wifi section of the router
Hisense TL1700... | Answered on Jul 23, 2016
It is possible that the backplane lamps and lamp supply has failed. It is also possible that there is a failure in the power supply or on one of the circuit boards. Without doing some tests it is impossible to accurately determine the areas of fault.
Jerry G.
Hisense TL1700... | Answered on Jun 18, 2016
Check out your power supply since set is sort of dead with no audio or video.
Hisense TL1700... | Answered on Mar 27, 2016
I would first try a different input and cable if possible.
Hisense TL1700... | Answered on Dec 03, 2014
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Hisense TL1700... | Answered on Sep 18, 2014
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Hisense TL1700... | Answered on Jul 30, 2014
Hisense TL1700 17 in. LCD Television Logo
144 questions posted
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
hisenese tv color went black white
  • Televison & Video
