Yes. The DG33 series can support the Q9400. See this document: https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/DG33FB.pdf
SOURCE: will Intel Core 2 Quad Q9300, 2.50 GHz processor
Motherboard info
Yes it'll work. Worst case scenario is that you will need to do a bios update. Overheat should not be a problem if you are using the intel reference cooler wich is provided with the cpu.
SOURCE: Will this CPU be compatible with this MOBO?
Okay your Processor is not supported by your System Board. I will take some time and look to see what would be a good upgrade, but it may take a few days.
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: Dose the intel core 2 quad core support SSE2 or 3 IS?
The quad core supports SSE, SSE2 and SSE3 instructions.
Regards.
SOURCE: want to install a Intel Core 2 Quad Q9400 S775
what type of motherboard and as for the 800/533 that sounds like memory speed not processor, you will also need to know the pin count on your mobo, to match your processor for example 775 or 1366,1166, looks like the processor you want to install is a 775, but i would make sure your mobo has the same pin count, take the part # from your mobo and manufacture and get back to me if you want :)
