20 Most Recent Intel DG31PR Motherboard Questions & Answers
The video card is a joke, strictly for office use. Get a GTS 250 , it's an very upgraded form of 9600GT. 8800GT is far too old and weak for newer games.
Intel DG31PR... | Answered on Mar 05, 2019
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Intel DG31PR... | Answered on Mar 16, 2018
u will get sound from tv tuner card only
Intel DG31PR... | Answered on May 06, 2017
check HDD and RAM, make sure your HDD new formated
Intel DG31PR... | Answered on May 24, 2016
Intel® Desktop Board DG31PRWindows 7, 32bit Drivers: http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows+7%2C+32-bit*&lang=eng&strOSs=189&submit=Go!Windows 7, 64bit Drivers:http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows+7%2C+64-bit*&lang=eng&strOSs=190&submit=Go!
Intel DG31PR... | Answered on Mar 02, 2016
This is usually dust clogging up the CPU cooler.
When the owner of the PC forgets to clean the fins and the fan of the CPU cooler it plugs up with dust and dirt and looks like the inside of a vacuum cleaner.
There is not enough airflow and thus not enough cooling, so the CPU overheats and the safety circuit shuts the CPU off until it cools down, and the CPU will not reboot the PC until it is cool enough that the safety circuit can reset.
First step remove the CPU fan and check the fins of the CPU cooler. If they are clean, the problem is usually somewhere else.
Intel DG31PR... | Answered on Oct 04, 2015
www.intel.com go to support
Intel DG31PR... | Answered on May 25, 2015
Hi
You don't give a specific problem with this motherboard but the link below takes you to the Intel website page from which all the drivers can be downloaded
https://downloadcenter.intel.com/SearchResult.aspx?lang=&ProductID=2839&ProdId=2839
Hope this helps
Cheers
Intel DG31PR... | Answered on Jul 25, 2014
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Intel DG31PR... | Answered on May 23, 2014
get a new video card or monitor maybe bad
take out battery for cmos make sure that the power is off first wait 1 min then put it back in
Intel DG31PR... | Answered on May 21, 2014
take out the battery before the startup wait one min then put it back in
put in a internal one in then and then install drivers
Intel DG31PR... | Answered on May 19, 2014
try a new one or see if your driver are installed
Intel DG31PR... | Answered on May 10, 2014
If you take the memory out so there's no memory in it, do you get a error code or beep?
Intel DG31PR... | Answered on Apr 26, 2014
Intel DG31PR Motherboard Logo
902 questions posted
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
dg31pr quad core not work
  • Computers & Internet
