Model LFGF3052TFA
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1
1. Watchdog on board
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven temperature sensor
F3 F4
Open or shorted oven temperature sensor
Replace
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
F7
Function key shorted
Replace touch pad
F8
Analog/Digital converter
F9
Door latch
Check door lock circuit
F10
Function key stuck
Replace touch pad
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: Removing the refrigerator drawers from the Electrolux side-by-side refrigerator
Got it. My mother got one of these fridges and was frustrated with the drawers not sliding off to clean. It is designed to dissamble the complete drawer assembly. Start by removing the glass from the top of the chill zone drawer frame. Next grasp the white piece of plastic that the chill zone is written on and pull up. There are 4 pegs which affix the drawer assembly to the fridge. The front two pegs will pop out and then the rear will easily pull. The top drawer assembly must be removed before the bottom two drawer assemblies can be removed.
I also noticed the plastic pieces and tried to pinch them but I couldn't get them to budge. Once I saw the 4 pegs, it made sense.
SOURCE: gas range, can't remove bottom oven panel - frigidaire FGFB55ASD
It pulls out toward the back or the oven. I usually lift it up as high as I can before yanking on it. If it is stuck, try sliding 2 small screwdrivers in the screw holes for more yanking leverage. As a lats resort, pry it out from the front; you may damage the finish this way. Hope this helps!
SOURCE: Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
I appreciate your inquiry, Tiffany Robinson!
I understand that you need assistance in removing your broiler drawer on your Frigidaire range. Could you provide the model number, please? With the model number I would be able to provide you further assistance. You can locate the serial tag (which lists your model number) on the door frame behind the bottom drawer. Once I have additional information I would be able to assist you better. I look forward to helping you. -Matt
Hi friend, I appreciate your inquiry
Based off the information you have provided it sounds like a possible issue within the element in your warming drawer or the sensor. You may have to schedule a technician to come out and evaluate any damage a spillover may have caused with your drawer. I hope this has been helpful. -Matt
That's a great question, friend!
I see you question is labeled under model FGES3065KB. In order to remove the drawer on that specific Frigidaire range you would need to follow these steps:
1. Open the drawer to full position.
2. Locate the latches on both sides of the drawer.
3. Pull up on the left glide latch and push down on the right glide latch.
4. Pull the drawer away from your range.
I hope this information is helpful to you. -Matt
