SOURCE: PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
