20 Most Recent Samsung DA-E750 Audio Dock Questions & Answers
Small claims court or contact Samsung customer service to see if they can step you thru the process---usually it is holding certain buttons with unit on to exit the demo mode.
Samsung DA-E750... | Answered on Dec 03, 2012
Hi Bill, your Samsung TV, has digital audio output by fiber optic, to be able to connect powered speakers, they must have that type of input
You can connect this output to an amplifier with Digital Fiber Optic input and thus have the audio in the amplifier speakers
Another option is to use a converter of Digital Audio input (Optical Fiber or Coax) and Audio output by RCA
I send you the link of the D / A converter
I hope you can listen to your TV by external speakers
Greetings Franco Dosil
Hola Bill, tu TV Samsung, tiene salida de audio digital por Fibra ?ptica, para poder conectar parlantes potenciados, estos deber?n contar con ese tipo de entrada
Puedes conectar esta salida a un amplificador con entrada Digital de Fibra ?ptica y as? tener el audio en los parlantes del amplificador
Otra opci?n es utilizar un conversor de entrada de Audio Digital(Fibra ?ptica o Coaxil) y salida de Audio por RCA
Te envi? el link del conversor D/A
Espero puedas escuchar tu TV por los parlantes externos
Saludos Franco Dosil
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_MX&CttFileID=6033976&CDCttType=UM&ModelType=N&ModelName=UN32J4000AF&VPath=UM/201510/20151030153502738/J4000-ZX-BF_BN68-07180Y-00ENG-0728.pdf&OriginYN=N
https://www.ad-net.com.tw/product/2-port-rca-audio-1-stereo-fiber-optical-converter
Samsung Audio... | Answered on Aug 12, 2019
how about this mov to avi converter
I saw it was suggested in similar question
Samsung Audio... | Answered on Jul 30, 2019
You can buy a hdmi to rca female out convertor on ebay, you will also need rca cables red/white (audio) and yellow for video.
Hope this helps.
Samsung Audio... | Answered on Jul 18, 2019
Visit the Samsung consumer site as they have free online manuals for most of their products.
OR Google the model number with "manual" to try to locate one.
Samsung Audio... | Answered on Jul 02, 2019
The RX-V371 may not be compatible with the Samsung TV.
Samsung Audio... | Answered on Jun 27, 2019
The 40" version of the Samsung 5200 series 5, UN40J5200AF, does have a 3.5 mm (mini) headphone/speaker audio out jack. See the specifications here, http://www.samsung.com/ca/support/model/UN40J5200AFXZC/ ; just expand the section for More Specifications. This is also shown on page 6 of the e-Manual (expand the Manuals section). The direct link to the e-Manual is currently http://downloadcenter.samsung.com/content/UM/201504/20150417115111056/ENG-US_NMATSCJ-1.104-0410.pdf , according to my history.
I hope this helps. If you have a different TV in the series, check the specifications at Samsung's support site. There may be variations in the input/output options on the other TVs.
If you can download the software from Samsung website, put it on a flash drive. Plug into the computer. Run the program. OR, you may be able to download and install the software from Samsung website directly. Go here for more information:
http://www.driverscape.com/download/samsung-yp-t9
Samsung Audio... | Answered on Jun 20, 2019
This TV does not have a headphone jack. It only has a optical digital audio output, Toslink. To connect this to most headphones, you'll need a digital to analog audio converter. You'll need to provide the cables (optical digital audio, RCA (M/M) to 3.5 mm (F) adapter). For some headphones, you can use just RCA audio cables or RCA (M/M) to 3.5 mm (M) audio cable. Here is one converter: https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA .
The documentation for the LN40B500P3FXZA is available here: https://www.samsung.com/ca/support/model/LN40B500P3FXZA/ . See page 4 of the User Guide for the back panel connections. The current link to this guide is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_CA&CttFileID=2430065&CDCttType=UM&ModelType=N&ModelName=LN40B500P3F&VPath=UM/201104/20110426143440007/BN68-01883Q-00L03-110426.pdf&OriginYN=N .
I wish I had better news for you. I hope this helps.
Samsung Audio... | Answered on Jun 13, 2019
Try unplugging it for 15 to 30 minutes and try again. Mine did this last year and unplugging it got it working again. I had to reconfigure the settings again.
Samsung Audio... | Answered on Jun 10, 2019
Samsung DA-E750 Audio Dock Logo
1 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
saumsung da e750 ex display model stuck
  • Audio Players & Recorders
