20 Most Recent Samsung HT-DM550 System Questions & Answers
Most likely, your unit has a condition known as DC Offset, meaning you have a bad amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
Samsung HT-DM550... | Answered on Dec 05, 2013
Be careful to do this with AC cable disconnected from AC outlet! If you have some experience with electronics, disconnect the wired plugs from power supply and discharge electrolitic capacitors to ground with a 330 ohm 1 watt resistor. Then reconnect the wired plugs. Be careful to do this with AC cable disconnected from AC outlet! Then connect to AC outlet and turn on the DVD player. You will see that DVD player restores to normal operation again.
dady_happy@hotmail.com
Samsung HT-DM550... | Answered on Nov 04, 2010
Start with checking your speaker wires, alot of times if you have positive & negitive crossing it will cause this issue
Samsung HT-DM550... | Answered on Dec 28, 2009
First check the speaker maybe one are on bad conditions and ready to burn,if they are fine the other cause be the audio amplifier IC
Samsung HT-DM550... | Answered on Jul 25, 2009
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
Samsung HT-DM550... | Answered on Mar 30, 2009
This is a problem with the lens..
Get a lens cleaner CD with liquid and clean your DVD drive(just put two drops of liquid on CD and press play)
If this doesn't work you will need to replace the lens...The repair cost is not very high for replacing lens..
Samsung HT-DM550... | Answered on Oct 18, 2007
Maybe you shoulkdjust look at it to see if it's clogged up with dust. The manual says to leave 4" of clearance around the fan opening.
The manual...
http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf
Live chat with samsung might get you a part number:
http://www.samsung.com/us/support/owners/product/HT-Z410#
email support:
Call : 1-800-726-7864
Samsung Audio... | Answered Yesterday
Go to http://www.samsung.com/us/support/#
enter your exact model number and it should give you a link to register your product with Samsung.
Without the model number, I cannot give you a more precise answer.
Samsung Audio... | Answered on Sep 19, 2019
Samsung HT-DM550 System Logo
Popular Tags
13 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
cutting out samsung ht thx22
  • Audio Players & Recorders
