Dishwashers Logo
Brianna Posted on Dec 01, 2018
Lxe Hobart dishwasher stuck on shutdown but won’t drain
2 Related Answers
Anonymous
  • 68 Answers
  • Posted on May 10, 2008
SOURCE: Hobart SR24C-4 Dishwasher can't drain completely
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Go to page 12.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/860F7951C087BD7F85256D36004978EA/$File/F43078.pdf
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
Anonymous
  • 86 Answers
  • Posted on Sep 19, 2010
SOURCE: my sr24h hobart undercounter dishwasher is stuck
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
How do I delime a Hobart LXE series dishwasher?
run load empty with a cup off salt in place of detergent
Hot to do a hard reset on my hobart lxe
LXE machines have a lockup issue, which is supposed to be fixed with a new control board. It has to be revision H or higher. Do not accept an older revision.
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 • Dishwashers
1helpful
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
The display on the hobart am 15 dishwasher when cycled beeps and scrolls DRAIN across the screen
Check thte drain hose as it might be clogged at the entry point to the drain if it connected to a garbage disposer.
The code EO comes on after the thrid cycle on our Hobart glass washer what should I do
E0 STANDS FOR NO WATER @SUMP PROBE DURING 3 CONC. CYCLES. MY FIRST GUESS WOULD BE THERE IS SOMETHING STUCK IN YOUR DRAIN VALVE ALLOWING ALL THE WATER TO GET PUMPED OUT INSTEAD OF WASHING AND STAYING IN THE TANK. DONT FORGET TO VOTE
Horbart dishwaser wont dran
Its a hobart correct?The data plate is on the bottom right front or on the door when opened on the left.If you dont see it then its been removed.Regardless does the display show a wash then rinse cycle?If so and it doesnt drain you either have a clogged drain hose or the drain valve is bad or stuck.If you use this just to wash glasses your model is probably a lxigc.If glasses are broken in the dishwasher which they probably are the glass has gotten into the drain body and is obstructing the valve from opening and closing.I work for hobart and services dishwashers alot.let me know.
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
