20 Most Recent Hobart SR24-H Built-in Dishwasher Questions & Answers
Pump bearings, staff dropped a teaspoon down the inlet to the pump. You need a service engineer. Don't run it.
I have been in the hospitality for 45 years and seen it all. Our drain mechanism broke a month back and it was full of cocktail sticks. We just got a brand new machine.
Hobart SR24-H... | Answered on May 18, 2016
May be the water inlet valve.The screen could be clogged or the valve itself may be bad.
Hobart SR24-H... | Answered on Apr 15, 2014
The wash arm bushing for this model is not available separately. You can use the bushing from the LX series and cut it shorter to length. Hobart will not issue service manuals to non Hobart personel because of liability issues. If you injured yourself from misinterpreting the manual, they would apparently be resonsnsible.
Hobart SR24-H... | Answered on Mar 23, 2014
The timer works like a clock if you like. The cycle starts at 12:00 finishes around 11:55. When you open the door, the timer advances to the 12:00 position resetting itself to the start of a new cycle. The door has to be open for about 12 seconds. Check on the left side door hinge bracket and see how it plays on the door switch. old doors on the SR24's had an issue of the hinge screw coming loose which triggered the switch too soon. You should be able to rest the door against the tank without the maching running. The switch should close as the door engages the latch.
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Hobart SR24-H... | Answered on Jul 16, 2012
Sorry to read about your problem, I hope this helps you out.
you do not put soap inside the unit, you hook up 5 gallon soap buckets, their a plastic feed hoses..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Hobart SR24-H... | Answered on Dec 22, 2010
Hi James, This may sound a bit odd but... if you really want to make sure all of the water is out of the unit just remove the drain hose and use a shop vac to draw out all the residual water. Then just place about 1 to 1.5 cups of vegetable oil in the sump for the winter. I do not recommend anti-freeze due to the associated health reasons of same. Then next season remove the drain hose and draw out the vegetable oil before returning it to regular service. This works well for resorts in cold climates. The vegetable oil can over several seasons fatten up or harden pump seals but is no more harmful than the anti-freeze on the seals.
Thanks for choosing FixYa,
Kelly
Hobart SR24-H... | Answered on Oct 30, 2010
The unit you have is a pump out system.
Hobart SR24-H... | Answered on Sep 19, 2010
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Hobart SR24-H Built-in Dishwasher Logo
42 questions posted
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
open close door several times reset
  • Dishwashers
