20 Most Recent Hobart 29 in. AM15-1 Free-Standing Dishwasher Questions & Answers
2answers
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
8/9/2022 2:26:30 PM • Hobart 29 in.... • Answered on Aug 09, 2022
6answers
Error code E2
E2 means a problem with the fill. The wrench means to contact Hobart for service
10/18/2016 5:58:30 AM • Hobart 29 in.... • Answered on Oct 18, 2016
2answers
What brings on the P1 indication on the hobart dish washer
P1 = Wash tank probbe assy failure
10/18/2016 5:55:00 AM • Hobart 29 in.... • Answered on Oct 18, 2016
Refill solenoid not working
measurement on refilltime of programclock cable to solenoid or the the metal disc valve is stuck with lime little chance that lingers. Take off the two connection slide contacts and the solenoid coil of the shut-off valve to measure the flow passage
7/17/2016 4:08:04 PM • Hobart 29 in.... • Answered on Jul 17, 2016
Indicates problem with the temperature probe. Look in the tank where the float is and check to see if it is covered with debris. The float has a magnet that collects metal particles. The metal probe that is under the float is the temp. probe.
10/17/2014 1:08:03 PM • Hobart 29 in.... • Answered on Oct 17, 2014
Hobart am-15 ml-130038 displaying p1 error
I replaced the probe temp according to error code P1 but the display still shows error P1. Is there any suggestion for further troubleshooting?
10/10/2014 11:54:23 PM • Hobart 29 in.... • Answered on Oct 10, 2014
Why is my hobart am 15 not getting to wash temp or rinse temp
Need to look at heating elements
4/2/2014 10:30:53 AM • Hobart 29 in.... • Answered on Apr 02, 2014
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
3/23/2014 5:00:21 PM • Hobart 29 in.... • Answered on Mar 23, 2014
Display lights all on
some early machines were known to leak from around the front door supports, causing water to leak into the controls. Check the connections to the display and keypad. Please be more specific regarding a noise. is it all the time the pump is running? is it a contactor chattering? If you are going inside to check, keep in mind there could be atleast two circuits powering the machine and its booster. Practice lockout, tag out, at all times
3/23/2014 4:40:08 PM • Hobart 29 in.... • Answered on Mar 23, 2014
0answers
0answers
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
82 questions posted
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
refill solenoid not working
  • Dishwashers
