1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
SOURCE: HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light
Introduction
The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed.
Instructions
The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
Figure 1: Cartridge status icons
Icon/Drawing
Problem identified by the symbol
Solution
The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed.
1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
3. Check to make sure the color cartridge is appropriate for the printer.
4. If the problem persists, replace the color cartridge.
The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective.
1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
3. Check to make sure the black cartridge is appropriate for the printer.
4. If the problem persists, replace the black cartridge.
The color print cartridge is running low on ink.
Replace the color print cartridge with a new color print cartridge.
The black print cartridge is running low on ink.
Replace the black print cartridge with a new black print cartridge.
None. The print cartridges are working correctly.
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction
The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused.
NOTE:
The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking."
Blinking lights
Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first.
Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution.
Issue: Power light is blinking
Solution
Close the cover.
Cause
Printer cover is open.
Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper.
Solution
Cause
The printer has difficulty picking up label media.
Solution
Follow each of these steps until the problem is resolved:
Cause
There is a paper jam.
Solution
Cause
There is a problem with a print cartridge.
Solution
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
SOURCE: HP Deskjet 3915 Printer ''Door Open''
open all the doors (fron and back) make sure there is no paper jam .
close all doors, one at a time.
turn off, wait for a few seconds,,,
turn on
and your problems is solved.
SOURCE: 0xc19a0023
Have you tried flushing out the clogged ink from the printhead with distilled water ?
