SOURCE: My headset wont let me hear but i can talk to
generally not. these headsets are not real durable. Check your connections if you jiggle the plug, and you cut in and out: It's the plug. Get a new headset.
SOURCE: Cant Talk Through Turlte Beach Headset
Your controller cable may be broken. Here's the link to buy a new one:
http://www.turtlebeach.com/products/efx1/replacementparts.aspx
SOURCE: I can hear trough my headset but not talk
okay, this is obvious but first of all make sure this switch on your headset is not on mute. If alls good there go to your dashboard settings and you should see communication and make sure none of these are blocked. If this also isn't the problem it looks like you are going to need a new headset. It should have a years warrenty if that helps?
SOURCE: Hey,my madcatz headset for xbox
Are you muted? Check to make sure the mute button is not turned on. Also, check that the wire is firmly connected, as you might get, but not send sound. Check your settings in the dashboard as well in console settings, as it might be muted through there.
