20 Most Recent Icom IC-M505 - VHF/DSC Marine Transciever Questions & Answers
DUALWATCH/
Description
Dualwatch monitors Channel on another channel;
Tri-watch monitors Channel 16 call channel while receiving another is convenient for monitoring operating on another channel.
DUALWATCH/TRI-WATCH SIMULATION
Call channel
Dualwatch
Tri-watch
If a signal is received on Channel 16, Dualwatch/Tri-watch
pauses on Channel 16 until the signal disappears.
If a signal is received on the call channel during
Tri-watch,
Tri-watch becomes Dualwatch until the signal disappears.
To transmit on the selected channel during Dualwatch/Triwatch,
push and hold
[PTT]
Operation
q
Select Dualwatch or Tri-watch in Set mode. (p. w
Rotate [CHANNEL] to select the desired operating e
Push [DIAL•DUAL/GRP] for 1 sec. to start Dualwatch or
Tri-watch.
•"DDDU
UUA
AAL
LL
66" appears during Dualwatch; "
T
TTR
RRI
II
66" appears during
Tri-watch.
A
beep tone sounds when a signal is received on r
To cancel Dualwatch/Tri-watch, push
[DIAL•
DUAL/GRP]
again.
[Example]:
Operating Tri-watch on INT
Channel 25
Tri-watch
starts. Signal is received on call channel.
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
BUSYBUSY
25W25W
INTINT
CALLCALL
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
INTLINTL
Tri-watch resumes after the
Signal received on Channel
signal disappears.
16 takes priority.
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
BUSYBUSY
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
More user manuals on
ManualsBase.com
If not understand mail me sadiqm357@yahoo.com
Icom IC-M505 -... | Answered on Apr 25, 2019
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Icom IC-M505 -... | Answered on Feb 11, 2015
it is available on web sight..download it.
Icom Radio... | Answered on May 21, 2019
Contact Icom directly to inquire.
Icom Radio... | Answered on May 20, 2019
Contact iCOM directly to inquire.
Icom Radio... | Answered on May 17, 2019
Sure sounds like a "low volts" reboot due to high current draw.
Are you measuring voltage at the radio itself, after any connector, fuse or circuit breaker? The voltage (at the set) should be slightly different between low and medium power tx. Use a good meter to confirm this. Is the power supply able to supply the current required at high tx power? Is a current limiter operating? A lead-acid battery in parallel with the PSU might be needed at high power.
At high power setting the radio will probably reset faster than a low power input voltage can be measured with a normal meter, so an oscilloscope might be needed to see the power input voltage as it happens (might be very brief).
Could RF be getting back into the power supply? Does it happen on both bands? Is the SWR good? Is the earth good? How long and how thick are the power wires? Is there any filter on the power supply wires (close to the radio)? If it's new there will be a warranty if it's a fault in the unit. Good luck :)
Icom Radio... | Answered on Apr 28, 2019
Que es el error? Aye un numero? Diga mas acerca de este problema.
Icom Radio... | Answered on Apr 08, 2019
Icom IC-M505 - VHF/DSC Marine Transciever Logo
2 questions posted
Top Icom Radio Communications Experts
Perry Mellott
Perry Mellott
Robert McClure
Vincent G
Vincent G
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Icom Radio Communications
Most Popular Question
icom ic m505 refuses scan in setup
  • Radio Communications
